Marantz CD63SE Special Edition CD Player with remote
Marantz CD63SE Special Edition CD Player with remote Empty Marantz CD63SE Special Edition CD Player with remote
Post by HiFiLab on Fri Jul 19, 2019 9:52 am
Marantz CD63SE Special Edition CD Player with remote 20190714
Marantz CD63SE Special Edition CD Player with remote 20190715
Marantz CD63SE Special Edition CD Player with remote 20190716
Marantz CD63SE Special Edition CD Player with remote 20190717
Marantz CD63SE Special Edition CD Player with remote 20190718
Made In Japan
Price : RM 780
This is a legendary player - one of the all times best-sellers. Cheap but sounding like high end.
It has raw, dynamic, energetic, if maybe not most refined sound. Many companies used to tweak it and mod it, because it is such great base unit.
It has simple NPC SM5872 dac (Nippon Precision Circuits). Datasheet quotes: "CMOS LSI (Digital D/A Converters with Built-in Digital Filters
The  DECO SM5872A/B D/A converters are high-speed converters for digital audio systems. They are fabricated in Molybdenum-gate CMOS. They incorporate a two-channel, 16-bit D/A converter and a digital eight-times oversampling filter, making them ideal for use in PCM and CD players and digital amplifiers. The Σ DECO SM5872A/B operate at 32, 44.1 and 48kHz sampling frequencies and incorporate deemphasis, attenuation and soft mute functions. " End of quotation...
Anyway, CD63 was one of the first Marantzes using a non-Philips DAC. Still a philips mechanism althouh it is a very very cheap and flimsy application of CDM12.  The CD player has few op-amps, all elements are placed on one huge PCB, the output stage is minimalistic with tin-can- protected elements which may even be discrete. That would be  the simplest CD player with discrete output - but - wait a minute - the op-amps are still in the path or so it seems.
The specifications:
Digital converter: SM5872BS, 1 bit linear/ch
CD Mechanism: Philips CDM-12.1
Frequency response: 5Hz to 20kHz
Dynamic range: >96dB
S/N Ratio: >104dB
Channel separation: 102dB / 1kHz
THD: > 0.0025% / 1kHz
Line output: 2V
Digital outputs: coaxial: .05Vp-p/75 ohms S/PDIF,
optical -19dBm optical TOS link
Power consumption: 13/12 watt
Dimensions: 420 x 86 x 300mm
weight: 5.6 kg
HiFiLab
Number of posts : 2630
