NAD 412 Stereo FM Tuner Radio Digital
NAD 412 Stereo FM Tuner Radio Digital  Empty NAD 412 Stereo FM Tuner Radio Digital
Post by HiFiLab on Fri Jul 19, 2019 10:12 am
NAD 412 Stereo FM Tuner Radio Digital  20190725
NAD 412 Stereo FM Tuner Radio Digital  20190724
NAD 412 Stereo FM Tuner Radio Digital  20190726
NAD 412 Stereo FM Tuner Radio Digital  20190727
NAD 412 Stereo FM Tuner Radio Digital  20190728
NAD 412 Stereo FM Tuner Radio Digital  20190729
Price : RM 480
This is a high-quality audiophile tuner which will fulfill all of your FM needs. It is very easy to tune and store selected stations in the presets. It has a very positive feel in the way the buttons respond. It will truly make your music system "complete" and make very sweet music, leaving little to be desired. If you are on the lookout for a very good tuner for reasonable money, let your search end here. This one is something to be proud of. Thanks to NAD.
Prouduct Description and Features:
AM/FM Tuner
• 24 preset stations (12 FM, 12AM)
• 25kHz tuning steps
• NAD link
• Blend function
The NAD 412 has evolved from the award winning 402. The 402 was named "Best Tuner, 1994" by "What Hi Fi". Improvements include a new high clarity display and a re-designed chassis. The NAD 412 is a superlative product and it out-performs many other tuners that cost far more.
Employing high quality components in it's simple circuit topology give the unit (and it's predeccesor) the noise free, low distortion performance that have made NAD tuners famous. Only the most essential functions are employed resulting in an uncluttered front panel of a product that is simple to use.
24 stations (12 FM, 12AM) can be entered in the preset mode. They are stored in a non volatile memory which allows the preset stations to remain in memory even if the unit is unplugged from the mains supply. Unlike most other tuners, the 412 tunes in 25kHz increments. This, coupled with crystal oscillator controlled digital frequency synthesis makes for precise tuning and enables the user to fine tune to their desired stations with ease. A centre tune LED indicates that the 412 is accurately locked to the transmitted signal. The SEARCH mode allows the 412 to tune to the nearest strong station, up or down the band, whilst the TUNE mode allows rapid scanning through the band. In both modes the software "wraps" the frequency band around allowing you to skip directly from the top of the band to the bottom or vice versa.
When attempting to listen to weak stations, sometimes the background noise can become annoying and spoil the listeners enjoyment of the programme. The BLEND function reduces this noise whist still retaining adequate stereo separation. NAD link is provided, enabling the 412 to be remotely controlled by another NAD product that is also fitted with NAD link and which has an IR sensor.
PROUDUCT SPECIFICATIONS:
FM TUNER SECTION
Usable sensitivity 1.5µV 50dB quieting Mono 2.5µV Stereo 30.0µV 60dB quieting Mono 7.0µV Stereo 100µV Capture ratio (45dBf) 5dB IF rejection 75dB AM supression 54dB Selectivity, alternate channel 78dB Subcarrier suppression (19kHz and 38kHz) 60dB THD Mono 1KHz 50% mod. 0.2% Stereo L-R 1KHz 50% mod. 0.3% Stereo L+R 1KHz 50% mod. 0.2% Signal to noise ratio (65dBf IHF weighted) Mono 73dB Stereo 70dB Frequency response (30Hz - 15kHz) ±0.7dB Channel separation (1kHz) 40dB
AM TUNER SECTION
Usable sensitivity 7µV Selectivity 19dB Image rejection 36dB Signal to noise ratio (1mV input) 45dB THD (30% mod., 1mV input) 2% IF rejection 46dB Physical Specifications Dimensions (W x H x D) 435 x 76 x 295mm Net weight 3.6kg Shipping weight 4kg Power consumption 15W.
HiFiLab
Number of posts : 2630
