Quad 99 CDP-2 (pre,dac n cdp) CD PLAYER
Quad 99 CDP-2 (pre,dac n cdp) CD PLAYER Empty Quad 99 CDP-2 (pre,dac n cdp) CD PLAYER
Post by jbashok on Thu Jul 25, 2019 10:26 pm
Quad 99 CDP-2 (pre,dac n cdp) CD PLAYER Q110
Quad 99 CDP-2 (pre,dac n cdp) CD PLAYER Q310
Quad 99 CDP-2 (pre,dac n cdp) CD PLAYER Q510
QUAD 99 CDP-2
Specification
Max. Line Output Level (RCA) 2.4V RMS
Max Output Level (QuadLink) 5.3V RMS (balanced)
Frequency Response 20Hz to 20kHz(+0dB/-0.5dB)
Total Harmonic Distortion (THD) 0.002% at 1kHz
Signal to Noise ratio (S/N) 110dB, 24bit (20Hz - 20kHz)
Signal to Noise ratio (S/N) 95dB, 16bit (20Hz - 20kHz)
Crosstalk -100dB at 1kHz
Gain Error 0.5dB (@-90dB, 500Hz)
D/A convertor maximim resolution 24bit
D/A convertor maximum sampling resolution 192kHz
Digital Audio Inputs 3 x RCA Coax 75ohm SPDIF, 3 x Optical TosLink SPDIF
Digital Audio Outputs Optical TosLink SPDIF
Disc Compatibility CD-DA Conventional Audio, CD-R Recordable (finalised and unfinalised)
Dimensions (H x W x D) 80 x 321 x 310mm
QUAD CDP-2 in the metal grey finnish and in excellent condition.
This CDP-2 is an excellent piece of audio equipment. Not only is it a first-rate CD player, with Crystal 24bit/96kHz DACs, but has six digital inputs (3 x RCA Coax 75ohm SPDIF, 3 x Optical TosLink SPDIF) allowing it to work as DAC. Furthermore, those who do not listen to vinyl can forgo a Preamp since the Quad CDP-2 has two analogue outputs: a fixed and a variable. The CDP-2 can therefore be coupled directly to a power amp and controlled by the remote.
I had my Squeeze box Touch digitally coupled to the CDP-2 and enjoyed excellent streamed audio.
comes with ORIGINAL REMOTE.
 price Rm1960
WHATSAPP--- 0143413655---
VIEW N DEMO
 KL
jbashok
Number of posts : 1835
Quad 99 CDP-2 (pre,dac n cdp) CD PLAYER Empty Re: Quad 99 CDP-2 (pre,dac n cdp) CD PLAYER
Post by jbashok on Mon Aug 05, 2019 8:47 pm
up unit in ipoh now
jbashok
Post by jbashok on Thu Aug 15, 2019 8:53 pm
jbashok
Post by jbashok on Thu Sep 05, 2019 8:45 pm
jbashok
Post by jbashok on Wed Sep 18, 2019 10:34 am
jbashok
