Starkesound sw12 subwoofer (Sol)
Starkesound sw12 subwoofer (Sol) Empty Starkesound sw12 subwoofer (Sol)
Post by William sow on Thu Aug 01, 2019 12:00 am
[size=30]Lower Cost - Higher Performance Key Features:[/size]
On a tight budget but don't want to settle for less? Starke Sound’s mission has always been to serve our fellow audio enthusiasts. Behold, the SW12 is our solution to your problem: a subwoofer with a discreet appearance that does not compromise on performance. With a 12-inch high-performance driver and an amplifier of up to 900W peak power, this, is the weapon to shake your room.
[size=30]Key Features:[/size]
Great performance,great value for the price range
Uncompromised Deep Bass(Down to 23hz)
Built in 900watt ClassD amplifier(max)
12-inch powerful driver
115/230V switchable
SpecificationSW12
AmplifierRMS power 450W, Short term power 900W
Driver 12 inch drivers
Frequency Response (+-3dB)23Hz to 250Hz
Crossover50Hz to 200Hz (variable in 1 Hz increments)
Phase Control0 - 180 Degrees
Voice CoilDouble Four-layer, 50.5mm, PICCAW wire
Auto On/Off Yes
Volt Switch230V/115V
CabinetSealed Box
Grille Yes
Color optionsBlack Matte
Dimensions: (H x W x D)14.9 x 14.9 x 16.7 inches (w/o foot)
380 x 380 x 425mm (w/o foot)
15.7 x 14.9 x 16.7 inches (w/ foot)
400 x 380 x 425mm (w/ foot)
Shipping Size: (L x W x H)
515 x 470 x 475mm
20.2 x 18.5 x 18.7 inches
Weight39.5 lbs(18kg)
Shipping Weight44 lbs(20kg)
Warranty3 years (electronics
Starkesound sw12 subwoofer (Sol) 10-10010
Starkesound sw12 subwoofer (Sol) 11-10010
Price:Sold
Contact:01112113236 William
William sow
Number of posts : 11
Registration date : 2018-11-30
Starkesound sw12 subwoofer (Sol) Empty Re: Starkesound sw12 subwoofer (Sol)
Post by William sow on Fri Aug 16, 2019 2:55 pm
William sow
Post by William sow on Fri Aug 23, 2019 2:12 pm
William sow
Post by William sow on Wed Sep 04, 2019 9:07 am
William sow
Post by William sow on Sat Sep 14, 2019 12:24 am
William sow
Post by William sow on Mon Sep 23, 2019 7:45 am
William sow
Post by William sow on Mon Oct 07, 2019 6:39 pm
William sow
Post by William sow on Sun Oct 20, 2019 8:53 am
William sow
