Inakustik Referenz Speaker Cable LS-1302 - 3m pair
Page 1 of 1 • Share
Item: Inakustik Referenz Speaker Cable LS-1302 - 3m pair
Condition: 8.5/10. Item is in excellent condition.
Price: RM2200 or swap/topup
The follow-up to the legendary LS-1202 was awarded a “highlight” in a test carried out by the magazine “stereoplay” (10/2007). The PE network jacket reduces micro-vibration, the large cable cross-section delivers outstanding and controlled low frequency reproduction. The 24 solid conductors surround a polyethylene carrier, which largely consists of the best insulation material of all - air. The LS-1302 is suitable for single wire and single bi-wire applications.
Features:
Hue / Color:
Each cable has its own characteristics and even its own "character", which is reflected in its own doorbell. This is due to its technical construction and materials used in manufacturing. The diagram shows how the described cable is positioned and where its strengths are. The relationship indicated by numbers is based on Inakustik's own knowledge and experience, as well as his statistical calculations. It serves as a solid and easy to understand guide, as well as to buy several products and be a great help for the selection and purchase decision.
The further development of the legendary LS-1202. 24 DUO PE II insulated DSS conductors. Extremely
low inductivity due to PETS Technology. Nearly no Skin Effect because of big conductor surface. With PE Network-
Jacket for lowest capacity.
Versions:
https://www.in-akustik.de/
http://www.hifisupply.nl/index.php?item=inakustik-speaker-cable-ls-1302-2x3_0m--per-paar&action=article&aid=14771&lang=en
[size=32]Inakustik Referenz LS-1302[/size] | |
More information at http://www.in-akustik.com/ | ![]() |
SPEAKER CABLE 2 x 3 m HIGH-END PERFORMANCE |
Features:
- 24 solid conductors for identical transit times
- Alternate arrangement of the conductors neutralises magnetic fields
- Oxygen-free OFC copper
- The best “insulation material”, air, in the core - for low capacitance.
- DUO-PE II insulation around each conductor
- PE network jacket reduces micro-vibrations and capacitance
Hue / Color:
- Product info
- Low loss PE network jacket
- Reduced Micro-Vibrations
- Improved sound stage
- Duo-PE II Insulation low inductance for smooth performance
- High precision Solid Core conductors
- Single-Layer Hollow Conductor
Versions:
- Easy plug single wire
- Easy plug single bi-wire
- BFA banana single wire
- BFA banana single bi-wire
- Spade 6/8mm single wire
- Spade 6/8mm single bi-wire
- Screw type single wire
- Screw type singe bi-wire
