Mordaunt Short MS-502 Floorstanding Speaker Equipped with 10 Inch Active SUB
Mordaunt Short MS-502 Floorstanding Speaker Equipped with 10 Inch Active SUB Empty Mordaunt Short MS-502 Floorstanding Speaker Equipped with 10 Inch Active SUB
Post by HiFiLab on Sat Aug 10, 2019 4:47 pm
Mordaunt Short MS-502 Floorstanding Speaker Equipped with 10 Inch Active SUB 20190810
Mordaunt Short MS-502 Floorstanding Speaker Equipped with 10 Inch Active SUB 20190811
Mordaunt Short MS-502 Floorstanding Speaker Equipped with 10 Inch Active SUB 20190812
Mordaunt Short MS-502 Floorstanding Speaker Equipped with 10 Inch Active SUB 20190813
Mordaunt Short MS-502 Floorstanding Speaker Equipped with 10 Inch Active SUB 20190815
Mordaunt Short MS-502 Floorstanding Speaker Equipped with 10 Inch Active SUB 20190814
Mordaunt Short MS-502 Floorstanding Speaker Equipped with 10 Inch Active SUB 20190816
Mordaunt Short MS-502 Floorstanding Speaker Equipped with 10 Inch Active SUB 20190817
Mordaunt Short MS-502 Floorstanding Speaker Equipped with 10 Inch Active SUB 20190818
Price : RM 5800
Mordaunt Short MS 502, Very powerful all round floorstanding speaker, Equipped with it's own built in sub for extended low frequencies.
Each left and right speaker features one 1" aluminium diaphragm tweeter and two 5ΒΌ" CPC mid/bass units. Low frequencies are delivered via a powerful 10" bass unit which is housed within its own sub enclosure and is served by a discreet 150W power amplifier.
The amplifier features adjustable volume control, 2 crossover positions (internal and external), as well as a single band Parametric EQ for best possible bass performance. The inclusion of a phase reverse switch also allows for better system integration.
User Manual for reference:
http://www.manualsdir.com/manuals/125044/mordaunt-short-500-series-thx.html?page=6
User Review for reference :
http://www.audioreview.com/product/speakers/floorstanding-speakers/mordaunt-short/thx-502.html
HiFiLab
Number of posts : 2629
Mordaunt Short MS-502 Floorstanding Speaker Equipped with 10 Inch Active SUB Empty Bump
Post by HiFiLab on Sun Jan 05, 2020 10:20 am
Up
HiFiLab
