Line Magnetic 508IA Tube Integrated Amplifier
Item: Line Magnetic 508IA Tube Integrated Amplifier
Price: sold
[size=32]Line magnetic Audio LM-508IA 300B 805 integrated Amplifier Class A single-ended & Power Amplifier
Features:
Black panel,both dignified and graceful.
Poweramp adopt audio grade with 805 output high power tubes as single-ended
class A power amplification.
Extraposition 805 current adjustment(BIAS ADJ.)and hum balance adjustment
(HUM BALANCE).
You can use a variety of brands and models tubes,listen to the different rhyme.
Totallyhandmade,The whole machine adopts some welding booths.
Interstage use the German high quality N - cap coupling capacitance.
Using two high quality EI to promote output transformer and output transformer.
Using the specifical development for the native circular area power transformer.
With high pressure power supply and the filament preheating function,extend the
life of the tube.
Select the Japan ALPS high-grade motor potentiometer.
Infrared remote control function.
Specification:
Power output: 48W+48W
Frequency response: 20Hz~31kHz(-1.5dB)
THD: 1%(1kHz)
S/N Ratio: 87dB A Weighted
Input Sensitivity: Line 330mV Pre 1000mv
Input Impedance: 100kΩ
Output Impedance: 4Ω , 8Ω , 16Ω
Dimension (WxDxH): 430mm X 420mm X 270mm
Tube Complement: 6SL7 x1、6SN7 x2、805 x2、300B x2
Net Weight: 40kg
Gross Weight: 43kg
Power Supply: AC 220V±5%(50Hz/60Hz)
Power Consumption: 400W
Working Condition: Temperature: 0℃~40℃ Moisture: 20%~80%
Storage Condition: Temperature: -20℃~70℃ Moisture: 20%~90%
http://audio-revolutions.com/product/lm-508ia/
https://www.usaudiomart.com/details/649465006-line-magnetic-508ia-integrated-amplifier/
https://www.usaudiomart.com/details/649370357-mint-line-magnetic-508ia-fantastic-45watt-of-set-goodness/
https://reverb.com/item/17478397-line-magnetic-508ia-single-ended-triode-vacuum-tube-2018-black-class-a-set-integrated
https://www.aliexpress.com/item/32972332852.html?spm=a2g0o.productlist.0.0.459a6bdfAhQ74m&algo_pvid=c383147b-478f-454c-8a6b-8c92df7633e5&algo_expid=c383147b-478f-454c-8a6b-8c92df7633e5-0&btsid=72576356-e522-4ad2-ba55-a5ab4a242d41&ws_ab_test=searchweb0_0,searchweb201602_6,searchweb201603_60
Price: sold
100% Brand new[/size]
Line magnetic LM-508IA is an integrated Amplifier, it is a Power Amplifier too. (there is 1 pair of Power amp input)
It come with a remote control and a tube cage cover.
Features:
(HUM BALANCE).
life of the tube.
Specification:
THD: 1%(1kHz)
Net Weight: 40kg
Gross Weight: 43kg
- Power output
2 x 48W RMS Class A - Frequency Response
20 Hz – 31 kHz, -1.5db - Input sensitivity
330mV (as integrated amplifier),
1000mV (as stereo power amplifier) - Input impedance
100Kohms - Output load impedance
4ohms, 8ohms, 16ohms selectable - THD+N
≤ 1 %/ 1Khz - S/N ratio:
≥ 87 db - Power Consumption
400W - Dimension
W x H x D : 430 x 217 x 355 mm
Product Number: LM-508IA
» Line Magnetic LM-508IA Integrated Amplifier (Sold)
» Line Magnetic LM-218IA 845 tube amplifier (sold)
» Line Magnetic LM-216iA Integrated Tube Amplifier (sold)
» Line Magnetic vacuum tube integrated amplifier LM 216IA (KT88)
» line magnetic lm 508IA intergrated amp
