Sonus Faber Amati Futura Graphite £7,900.00
Sonus Faber Amati Futura Graphite £7,900.00 Empty Sonus Faber Amati Futura Graphite £7,900.00
Post by audiomarket on Sun Aug 18, 2019 12:04 am
Product: Sonus Faber Amati Futura Graphite
Serial Number: 747/*
Cosmetic Description: The product is 100% perfect condition as new. It was not repaired, it has no scratch, no defect.
What is Included: Pair of speakers, Spikes, Casters, Factory shipping crates.
Functional Notes: Operational condition of this item is excellent, fully tested and no issues found.
Age: December 2016
# of Owners: 1
Tobacco Exposure: No
Service History: None
Description: Three-and-a-half-way, reflex-loaded, floorstanding loudspeaker. Drive-units: 1.1" (29mm) soft-dome tweeter, 7" (179mm) cellulose-fiber midrange cone, two 8.75" (220mm) aluminum-magnesium–alloy cone woofers. Crossover frequencies: 80Hz, 220Hz, 3.3kHz. Frequency range: 25Hz–30kHz. Sensitivity: 90dB/2.83V/m. Nominal impedance: 4 ohms. Rated input power: 30–300W without clipping.
Dimensions: 45.7" (1160mm) H by 16" (405mm) W by 25" (635mm) D. Weight: 122 lbs (55.5kg) net each; 319 lbs (145kg)/pair shipping.
Finish: High-gloss lacquered wood veneer with leather-covered front baffle and silver-colored metal top and bottom plates and rear fins.
产品:Sonus Faber Amati Futura石墨
编号:747 / *
化妆品说明:该产品是100%完美的新条件。它没有修复,没有划痕,没有缺陷。
包含的内容:一对扬声器,尖钉,脚轮,工厂运输箱。
功能说明:此项目的操作条件非常好,经过全面测试,未发现任何问题。
年龄:2016年12月
业主数量:1
烟草暴露:没有
服务历史:无
描述:三个半,反射式落地式扬声器。驱动单元:1.1“(29mm)软球顶高音单元,7”(179mm)纤维素纤维中音锥,两个8.75“(220mm)铝镁合金锥形低音单元。交叉频率:80Hz,220Hz,3.3kHz。频率范围:25Hz-30kHz。灵敏度:90dB / 2.83V / m。标称阻抗:4欧姆。额定输入功率:30-300W,无削波。
尺寸:45.7“(1160mm)H乘16”(405mm)W乘25“(635mm)D。重量:每个净重122磅(55.5千克); 319磅(145千克)/一对运输。
表面处理:高光漆木饰面,皮革覆盖前挡板和银色金属顶板和底板以及后翅片。
www.audiohifimarket.com
audiohifimarket@gmail.com
Phone & WhatsApp +44 793 858 7652
Sonus Faber Amati Futura Graphite £7,900.00 20190110
audiomarket
audiomarket
Number of posts : 112
Registration date : 2019-04-17
https://www.audiohifimarket.com
Sonus Faber Amati Futura Graphite £7,900.00 Empty Re: Sonus Faber Amati Futura Graphite £7,900.00
Post by audiomarket on Fri Aug 23, 2019 8:51 pm
audiomarket
audiomarket
Post by audiomarket on Mon Sep 23, 2019 2:31 pm
audiomarket
audiomarket
Post by audiomarket on Sat Oct 05, 2019 3:56 am
audiomarket
audiomarket
Post by audiomarket on Sat Jan 25, 2020 2:07 am
audiomarket
audiomarket
