MARANTZ MA500 Power Amplifier Pair Mono Block
MARANTZ MA500 Power Amplifier Pair Mono Block Empty MARANTZ MA500 Power Amplifier Pair Mono Block
Post by arichume on Wed Aug 21, 2019 2:46 pm
Product Information
Treat your family and guests to quality entertainment by using the Marantz MA-500 1 Channel Power Mono Amplifier. This unit is compact enough to be functional and stylish in practically any spot in a room. Able to deliver 125 watts into 8 ohms, this product is ideal for powering just about any speaker. In fact, it can create a new multi-channel home theater or provide an additional channel for amplifiers to an existing system. An RC-5 remote control also makes it possible for users to change settings without getting up from the comfort of their seats. This black amp weighs a mere 13.2 pounds, which makes it possible for users to move it easily from one spot to another. They measure 19 inches in depth by 3.5 inches in width by 6 inches in height.This Monoblock equipment is specifically designed for use in home theaters and surround-sound system setups. The 125-watt and 180-watt performance delivers high power into 8-ohm loads, ensuring that users don't lose signals even in challenging audio environments. A frequency response between 10 and 100K combines with a signal-to-noise ratio of less than 116 decibels, making it a practical choice for beginners who want a high-tech music solution that can easily synchronize with a variety of music systems and accessories. The product can be bridged at 8 ohms for a total of 360 watts.This isn’t just a reliable product for home theater and small professional setups. The amp also boasts an excellent reputation for its support for home computers, car subwoofers, speakers, and other accessories. In fact, these amps will never run out of breath. Marantz MA-500 1 Channel Power Amplifier can really provide a lot of RMS power. Buyers should not rule out flexible integration of these capable products because they can offer a pleasing experience when properly paired and tuned.This product delivers the kind of performance enthusiasts expect from the highest-end amp. It has plenty of reserve energy even when hooked up with some of the most modern speakers and receivers. As for performance, the sound quality will endure even at lows as low as 20 hertz. In addition, it will continue to show clear and precise mids and highs almost every time. Even non-audiophiles are likely to be impressed by the clear sound and amazing bass response. This is the kind of performance that’s sure to keep you on your toes. That’s particularly true when hooked up to phono preamplifier or even ma-9s2 block amps, receivers, advance stereo headphones, and other monoblock gear.Overall, the durability and audio quality of MA500 is sure to serve you well now, and even as audio technology advances. This is a great choice for casual listeners, audiophiles, and even professionals who want reliable equipment, small size, and high output. This is a sublime amplifier design that should satisfy even the most demanding listener.
Product Identifiers
BrandMarantz
MPNMA500
ModelMA-500
iinterested please contact Ari
Selling
012-2018745
$3,850.00
arichume
Number of posts : 14
Registration date : 2010-07-22
