Onkyo A-9130 Integrated Stereo Amplifier
Onkyo A-9130 Integrated Stereo Amplifier Brand New. Now Selling At RM2,199. Free Shipping Within West Malaysia.
HIGHLIGHTS
60 W + 60 W high-current amplification
WRAT (Wide Range Amplification Technology)
Direct Mode for source-authentic audio reproduction
Phase Matching Bass Boost
Custom-made high-current EI transformer and two 10,000 µF capacitors
Wolfson:registered: WM8718 DAC
MM phono input, 5 x RCA, and 2 x digital audio inputs
New fine display for easy source selection
AMPLIFICATION FEATURES
WRAT (Wide Range Amplifier Technology)
Customized high-current EI transformer
Two large custom-fabricated 10,000 µF audio-grade main capacitors
Optimum Gain Volume Circuitry for clear low-volume playback
Rigid anti-resonant 1.6 mm metal chassis
Four-ohm speaker-driving capability
High-quality Wolfson:registered: WM8718 192 kHz/24-bit D/A converter
Power Amp Direct main input function
Thick detachable IEC-compliant power cable
CONNECTION FEATURES
5 gold-plated analog RCA inputs
2 digital audio inputs (1 coaxial, 1 optical, 192 kHz/24-bit-capable)
1 phono input with discrete MM phono equalizer
1 analog RCA line-level output
Direct main power amp input
Subwoofer pre-out
High-quality non-magnetic speaker posts with clear knobs
Silver-plated 6.35 mm headphone jack
RI (Remote Interactive) input
ADDITIONAL FEATURES
Fine display shows active input
Aluminum volume control knob (motorized)
Independent bass and treble tone controls and balance control
Easy-to-use knobs for smooth operation without a remote
RI (Remote Interactive) input enables connection of a supported component for integrated control with one remote controller
Auto Power Standby
Available in silver or black
GENERAL SPECIFICATIONS
Power output: 60 W + 60 W (4 ohms, 20 Hz–20 kHz, 0.5% THD, 2-ch driven, IEC)
Frequency response: 10 Hz–100 kHz/+1 dB, -3 dB (Direct Mode)
Dimensions (W x H x D): 435 x 129 x 330 mm
Weight: 8.0 kg
A-9130
Integrated Stereo AmplifierHi-fi’s golden age reborn for modern listeners
The A-9130 is a robust and versatile pre-main amplifier with wide connectivity and deeply enjoyable sound quality. In pursuit of musicality and fidelity to the source, the amp is tuned for warm, lively sound that expresses the tonal colors of your best-loved albums. Stable high-current power delivers accurate and agile sound across a wide and dimensionally realistic soundstage. WRAT (Wide Range Amplification Technology) was fine-tuned specifically for the A-9130 by Onkyo’s master technicians. Two 10,000 μF main audio capacitors were custom-made following exhaustive listening tests to realize a richness and dynamism that’s very easy to love. Make the A-9130 the heart of your home hi-fi and enjoy the musical refinement expected of a far more expensive component.Refined Power Amplification
In order to deliver a clear and comfortable audio image, it’s vital that sounds of different frequencies arrive at the listening position simultaneously. Power amplification circuits feature original topology that’s carefully tuned for phase accuracy, wide-spectrum signal reproduction, and natural transient response. Fitted with hand-selected audio-grade parts, the amplifier contributes to lifelike and involving sound quality.Stable high-current power delivery
Dynamic changes in music cause impedance to fluctuate, placing huge loads on the amp. If it can’t meet power demands, sound breaks up. Onkyo’s WRAT employs a high-output EI transformer, 10,000 μF customized audio capacitors, and a low-impedance drive. As well as achieving more involving and musical sound, low-negative-feedback amplifier circuits with discrete transistors deliver deep and punchy bass thanks to wide frequency response covering 10 Hz–100 kHz.Direct Mode brings you closer to the source
Direct Mode bypasses tone and PM Bass circuitries. In combination with a refined amp circuit design, signal-path-lengths have been significantly reduced in comparison to the A-9030 for even more accurate and faithful sound. Enjoy end-to-end analog music reproduction from turntable to speakers, and recapture the atmosphere of the original recording with any connected source.Phase Matching Bass Boost enriches sound at low volume
Most pre-main amps have a loudness button designed to boost low-mid frequency sound. However, conventional designs are prone to phase-shift, which degrades the clarity of the vocal frequency band. Onkyo’s Phase Matching Bass Boost function eliminates phase-shift between low- and mid-range frequency bands above 300 Hz. Bass response is enhanced without compromising vocal clarity, and that’s something especially useful when playing music at low volume where bass and high-frequency sounds are more difficult to hear.New fine display shares info clearly
A new display panel boasts fine text resolution, making it easier to read at a distance than single bulbs. It shows active selected input at a glance.Quality speaker-posts make perfect contact
Speaker cables with your choice of terminal are firmly secured by high-quality speaker binding posts. Each wide-spaced non-magnetic post prevents interference and features a large, easy-to-grip transparent knob.Hi-fi-grade digital board with Wolfson:registered: DAC
Digital sources are decoded by a premium Wolfson WM8718 DAC on the A-9130’s digital audio board. This D/A converter is frequently installed on top-shelf audio components thanks to exceedingly good performance and supports 192 kHz/24-bit audio playback. TOSLINK or coaxial digital audio inputs are also ready to amp your TV entertainment, bringing powerful hi-fi sound to movies, games, sporting events, and live concerts. When an analog input signal is detected, the digital audio board shuts down automatically to reduce potential interference on the signal.Sounds clearer at low volumes
When playing music at low volume, the signal normally drops close to the component’s noise floor. The signal picks up noise, which is amplified, and the result is muffled sound. To avoid this, the A-9130 features Optimum Gain Volume Circuitry, which attenuates the signal by less than half the usual amount. The signal never approaches the noise floor so you can enjoy clearest sound at low volume.Thick and rigid chassis tames resonance
Every hi-fi component generates electromechanical resonance. This vibration translates into signal noise, and that impacts on the sound coming out of your speakers. To combat the negative effects of vibration, the A-9130 features a rigid chassis that’s fabricated from 1.6 mm-thick steel. Working together with large, wide-spaced insulators, unwanted resonance is virtually eliminated.HIGHLIGHTS
CONNECTION FEATURES
Subwoofer pre-out
ADDITIONAL FEATURES
Auto Power Standby
Weight: 8.0 kg
- Number of posts : 1250
» Onkyo A-9130 Integrated Stereo Amplifier (Sold)
» Onkyo A-9110 Integrated Stereo Amplifier
» Onkyo A-9130 Stereo Amplifier (Sold)
» Onkyo A-9911 Integrated Stereo Amplifier
» Onkyo A-9010 Integrated Amplifier + Onkyo C-7030 CD Player
