Audio Technica Isolators AT6091 from Japan - set of 4
Audio Technica Isolators AT6091 from Japan - set of 4 Empty Audio Technica Isolators AT6091 from Japan - set of 4
Post by HiFiLab on Sun Sep 15, 2019 6:40 pm
Audio Technica Isolators AT6091 from Japan - set of 4 20190939
Audio Technica Isolators AT6091 from Japan - set of 4 20190938
Audio Technica Isolators AT6091 from Japan - set of 4 20190940
Made In Japan
Price : RM 120
The Audio-Technica AT6091 Isolators are special anti-vibration rubber feet designed for use with audio and video high fidelity components such as CD and DVD players, turntables, amplifiers, pre amps, loudspeakers and video components. Placed under the cabinet of the chosen component, they dampen vibrations both on the vertical and horizontal plane and absorb the accompanying resonances that affect the sound quality of any high fidelity component. Each isolator has a load capacity of approximately 20 kg (44 lbs). With a set of 4 isolators, the load capacity is approximately 80 kg (176 lbs).
Features
- Set of 4 isolators
- Each isolator has a load capacity of about 20kg (44 lbs.)
- With a set of 4 isolators, the load capacity is approximately 80kg (176 lbs.)
- Isolators dampen vibrations both on the vertical and horizontal plane and absorb the accompanying resonances that affect the sound quality of any high fidelity component
- Size: 36mm x 9.5mm (1.42in diameter x .37in thickness)
HiFiLab
Number of posts : 2580
