Raphaelite MAS300 Phonostage (MM/MC)
Raphaelite MAS300 Phonostage (MM/MC) Empty Raphaelite MAS300 Phonostage (MM/MC)
Post by HIFI Illiterate on Wed Oct 02, 2019 3:11 pm
MAS300 is a high-end professional phonostage developed by Raphaelite. The in-house designed circuit structure consists of valve & op-amp as amplification & output. Combining a set of step-up (1:14) transformer (parmalloy core) with a wide-band width, the phonostage is able to have good input gain. Meanwhile, a set of step-up transformer (1:25) interface are reserved for further upgrade and to meet the requirement of different users.
MAS300 uses multiple sets of independent regulated linear power supply to supply power into the circuit, which improves the stability of the circuit. The fine-grained, multi-shielded aluminium casing ensures the high gain with low signal-to-noise ratio output of the phonostage.
Specifications:
Input voltage: AC 240V
Tube: Power section: 1*6C19; Amplification part 2*GE5670 (can replace WE396 /2C51/6N3)
Interface:
Input: 3*RCA stereo (2 MM 1 MC or 1 MM 2 MC with 1:25 step-up transformer)
Output: 2*RCA stereo 1*XLR stereo
Input impedance: MM 47KΩ         MC 4-100Ω
Input capacitance: MM/MC=100P/200P/OFF
Output gain: MM= 40dB         MC=60 dB
RIAA curve accuracy: ±0.8 dB
Distortion: < 1%@1 KHz
Signal to noise ratio: MM<80dB            MC<75dB
Output impedance: LOW (low impedance)=100Ω          HIGH (high impedance) = 47KΩ
XLR (balanced output) = 100Ω + 100Ω
Insulation resistance: 200MΩ (DC2000V.lMin)
Power consumption: 50W
Volume: 480*355*135
Net weight: 15KG
Price: RM8,200.00
Warranty: 1 year local warranty
Contact: Terence, 0176028532
Remarks: Audition can be arrange with advance appointment.
[You must be registered and logged in to see this link.]Raphaelite MAS300 Phonostage (MM/MC) Syyesu10[You must be registered and logged in to see this link.]
HIFI Illiterate
Number of posts : 601
Registration date : 2013-02-17
Source(s): Laptop with DAC
Amplification: Luxman Pre Power
Speakers: AcDynamics 3 Way Coaxial
https://www.facebook.com/acdynamics/
Raphaelite MAS300 Phonostage (MM/MC) Empty Re: Raphaelite MAS300 Phonostage (MM/MC)
Post by HIFI Illiterate on Wed Oct 09, 2019 5:11 pm
UP
HIFI Illiterate
Post by HIFI Illiterate on Wed Nov 06, 2019 10:51 am
UP
HIFI Illiterate
Post by HIFI Illiterate on Wed Dec 18, 2019 9:06 am
UP
HIFI Illiterate
Post by HIFI Illiterate on Wed Feb 05, 2020 11:22 am
UP
HIFI Illiterate
