Cayin A88-T MK2 REFERENCE Edition [SOLD]
FEATURES:
TECHNICAL:
Power output: 2 x 45W (ultralinear mode); 2 x 25W (triode mode)
Frequency Response: 10 Hz - 45 kHz, RMS
Input sensitivity: 300mV (line inputs) 1000mV (pre-amplifier input)
Input impedance: 100Kohms
Output load impedance: 4ohms, 8ohms selectable
THD+N: ≤ 1 %, 1Khz
S/N ratio: ≥ 93 db
Power Consumption: 280VA maximum
Dimension W x H x D : 420 x 195 x 382 mm
PRICE: SOLD brand new around RM11k++
tel:
- New Reference version of the highly acclaimed model
- Elegant high gloss wooden side benches
- Specially new designed output transformers for this edition
- Platinum matched quad 4 x GENALEX GOLD LION KT88
- High end purple copper speaker out terminals
- Teflon Silver plated high purity internal wiring
- Famous rich and noble Gold Lion KT88 sound
- Fully matched 6SN7 + 6SL7 for preamplifier session
- High precision VU meter on the top plate
- Bias adjustment easily done outside
- Accepts all kinds of EL34 / 6CA7 and KT88 / 6550 vacuum tubes
- Japan Takman carbonic film high end for audio resistors
- New protection circuitry for ac and audio transformers
- Power off memory function
- Automobile grade paint finish on top chassis
- Can be used as integrated amplifier or power amplifier
- High end Nichicon capacitors and audio choke coil
- High quality Japan ALPS motorized volume control
- Special handmade low magnetic leakage toroidal power transformer
- Ultralinear / Triode mode selection (selectable via remote control unit)
- All point to point wiring (hand soldering)
- Fully remote controllable
- 3 pairs RCA input + 1 pair RCA pre-amplifier input
- 4ohm / 8ohm selectable output load impedance
- Removable metallic tube protection cage included
- Detachable power cord system (IEC)
TECHNICAL:
THD+N: ≤ 1 %, 1Khz
S/N ratio: ≥ 93 db
tel:
Last edited by tongho on Mon Nov 04, 2019 2:08 pm; edited 2 times in total (Reason for editing : Price reduced)
tongho- Frequent Contributor
- Number of posts : 879
Amplification: Accuphase E470
Speakers: Quad z3
Re: Cayin A88-T MK2 REFERENCE Edition [SOLD]
Bump price reduced
Speakers: Quad z3
» Mordaunt-Short Speakers Performance 6 Limited Edition 40th Anniversary Edition (SOLD)
» CAYIN A-88T MK2 (SOLD)
» Cayin i5 DAP (Sold)
» Cayin mt-45 mk-2 plus (used) (sold)
» Cayin CDT-15A (SOLD)
