Paradigm Monitor 9 V7 Floorstanding
Paradigm Monitor 9 V7 Floorstanding Empty Paradigm Monitor 9 V7 Floorstanding
Post by emir786 on Fri Oct 25, 2019 4:17 pm
Price : RM2550 nego
Cosmetic : 9/10
Functionality : 10/10
Contact : 019-6873626
DESIGN : 4-driver, 2-1/2-way bass reflex, quasi-3rd-order resistive port, floorstanding model
FREQUENCY RESPONSE ON-AXIS : ±2dB from 46 Hz - 22 kHz
HIGH FREQUENCY DRIVER : 25-mm (1 in) S-PAL™ dome tweeter, ferro-fluid cooled and damped
MID/BASS FREQUENCY DRIVER : 140-mm (5-1/2 in) S-PAL™ cone, 25-mm (1 in) high-temperature voice-coil, oversize ceramic / ferrite magnets, GRIP™ chassis
LOW FREQUENCY DRIVER : Two 140-mm (5-1/2 in) carbon-infused polypropylene cones, 25-mm (1 in) high-temperature voice-coils, oversize ceramic / ferrite magnets, GRIP™ chassis
SENSITIVITY ROOM / ANECHOIC : 91 dB / 88 dB
IMPEDANCE : Compatible with 8 ohms
FINISHES : Black Ash, Heritage Cherry
WEIGHT : 42 lbs. (19.1 kg)
DIMENSIONS HxWxD : 40" × 6.875" × 10.5" (101.6cm × 17.5cm × 26.7cm)
LOW FREQUENCY EXTENSION : 31 Hz (DIN)
CROSSOVER : 3rd-order electro-acoustic at 2.0 kHz, 2nd-order electro-acoustic at 700 Hz (lower bass drivers)
FREQUENCY RESPONSE 30° OFF-AXIS : ±2dB from 46 Hz - 18 kHz
SUITABLE AMPLIFIER POWER RANGE : 15 - 200 watts
MAXIMUM INPUT POWER : 150 watts
Paradigm Monitor 9 V7 Floorstanding Whatsa17
Paradigm Monitor 9 V7 Floorstanding Whatsa18
Paradigm Monitor 9 V7 Floorstanding Whatsa19
Paradigm Monitor 9 V7 Floorstanding Whatsa20
emir786
Number of posts : 6
Registration date : 2018-10-19
