Accuphase C-200/P-300 Pre and Power Amplifier (Used) Price Reduced!!! SOLD
Accuphase vintage C-200/P-300 pre/power amplifier need not further introduction. This is the first audiophile matching pre/power models produced by Accuphase (known as Kensonic/Accuphase those days). It has made the name Accuphase so famous and where it started with all.
All buttons & switches are functioning. The power VU meters are working perfectly with beautiful warm light in the dark. Both units are in original condition (except P-300 have upgraded the two big power supply capacitors). No deep scratches or dent whatsoever. Consider excellent condition for its age.
The RCA sockets & Speaker terminals at the rear panel still very clean and no sign of oxidation. 4 pcs of Spade Fork Banana Plug will be provided for speaker terminals to accept common banana jacks.
I will not describe the sound here as you have to listen to it.
Note: Both units have set to local voltage (240VAC), Made in Japan
C-200
P-300
Power output: 150 watts per channel into 8Ω (stereo)
Please refer the link below for Manual/Spec and Reviews.
http://www.accuphase.com/cat/pcten.pdf
https://www.hifiengine.com/manual_library/accuphase/c-200.shtml
https://www.hifiengine.com/manual_library/accuphase/p-300.shtml
https://audio-database.com/Accuphase-kensonic/amp/C-200-e.html
https://audio-database.com/Accuphase-kensonic/amp/P-300-e.html
http://www.audioreview.com/product/amplification/preamplifiers/accuphase/c-200.html
http://www.audioreview.com/product/amplification/amplifiers/accuphase/p-300.html
Condition: 8/10
Price: SOLD
SMS or WhatsApp only. Billy 012-2821295
C-200
Total harmonic distortion: 0.05%
Input sensitivity: 2mV (MM), 200mV (line)
Signal to noise ratio: 73dB (MM), 90dB (line)
Output: 10V (Pre out Max)
Dimensions: 445 x 152 x 355mm
Weight: 14kg
P-300
Total harmonic distortion: 0.1%
Damping factor: 60
Input sensitivity: 1V
Signal to noise ratio: 100dB
Semiconductors: 73 x transistors, 1 x IC, 2 x thermistors
Weight: 25kg
Condition: 8/10
Price: SOLD
yppan- Frequent Contributor
- Number of posts : 526
» Accuphase C-200L + P-300L Pre and Power Amplifier (Used) Price Reduced! SOLD
» SOLD Cary Audio CAD-300SE Signature Monoblock SET Tube Power Amplifier - Price Reduced
» Accuphase DP-100 / DC-101 SACD transport / DAC (Used) (PRICE REDUCED!)
» (Price reduced)SMSL VMV A1 Power Amplifier
» Sansui C77 & B77 pre/power amplifier-SOLD
