Definitive Technology ProCenter 2000 Centre Speaker
Item: Definitive Technology ProCenter 2000 Centre Speaker
Condition: 8/10. Item is in very good working condition
Price: RM890 RM790 or swap/topup
[size=46]ProCenter 2000[/size]
Compact High Definition Center Channel Speaker
SPECS
GENERAL
SPEAKER SYSTEM
AUDIO SYSTEM
HEADER
MISCELLANEOUS
SPEAKER SYSTEM DETAILS
DRIVER DETAILS (1ST SPEAKER)
DIMENSIONS & WEIGHT
https://www.definitivetechnology.com/products/procenter-2000
https://www.cnet.com/products/definitive-technology-procenter-2000/
https://www.crutchfield.com/S-nG9DeCwRRfa/p_735PCTR2KB/Definitive-Technology-ProCenter-2000.html
Price:
- Rich audio from the best center channel speaker in the ProCinema Series
- Sounds bigger than its size while being easy to place
- Dual 5.25” pressure-coupled mid/bass radiators deliver warm, full-bodied sound
- Immerse yourself in high definition sound driven by exclusive BDSS technology
[size=65]SOUND THAT SPEAKS FOR ITSELF[/size]
The ProCenter 2000 is a revelation in sound. Built to unravel clearer dialog, more realistic details and up to 75% of a movie’s soundtrack, this world-class center channel loudspeaker uses identical BDSS:tm: drivers and two mid/bass radiators to produce peerless tonal accuracy that stands high above the competition.
SPECS
GENERAL
- Speaker System Type
center channel speaker - Manufacturer
SPEAKER SYSTEM
- Detachable Grilles
Yes - System Components
1 x Center channel speaker - Amplification Type
passive - Crossover Channel Qty
2-way - Frequency Response
42 - 30000 Hz - Nominal Impedance
8 Ohm - Recommended Amplifier Power
10 Watt - Sensitivity
91 dB - Magnetic Shield
Yes - Connectivity Technology
wired - Recommended Placing
bookshelf, on-wall mounted
AUDIO SYSTEM
- Type
HEADER
- Brand
Definitive Technology - Product Line
Definitive Technology ProCenter - Model
2000 - Packaged Quantity
1
MISCELLANEOUS
- Color
gloss black - Color Category
black
- Speaker Type
Center channel - Speaker Qty
1 - Frequency Response
42 Hz - Input Impedance
8 Ohm - Connectivity Technology
wired - Crossover Channel Qty
2-way
- Speaker Type
center channel speaker - Driver Type
mid/woofer driver, passive radiator, tweeter driver - Driver Qty
1, 2 - Driver Diameter
1 m, 5.25 m - Driver Diameter (metric)
133 mm, 25 mm - Driver Material
aluminum
DIMENSIONS & WEIGHT
- Width
17 in - Depth
6.5 in - Height
6.5 in - Weight
9.92 lbs
» Definitive Technology ProCenter 2000 Centre Speaker
» Definitive Technology BP 5ch Speaker set (USED)
