Benchmark DAC 1 Pre 24bit 192Khz
Benchmark DAC 1 Pre 24bit 192Khz Empty Benchmark DAC 1 Pre 24bit 192Khz
Post by laateedoo on Thu Nov 14, 2019 2:00 pm
For Sale : Benchmark DAC 1 Pre 24bit 192Khz
Price : RM1999 (nego)
Contact : david 0166415398 Watsapp
               message me for photo
Specification :
Benchmark DAC1 Features:
  • 2-channel, 24bit, 96-kHz D-to-A conversion
  • 192-kHz playback with 48kHz analog bandwidth
  • THD+N = -106dB (0.0005%) measured at -0 dBFS, any sample rate, any test frequency, with any degree of input jitter!
  • 116dB signal-to-noise ratio @48kHz, A weighted
  • AES/EBU (XLR & Coax) and S/PDIF (XLR, Coax, & Toslink) inputs
  • Digital input source-selection switch
  • Balanced, lo-Z XLR outputs
  • +29 dBu output level capability
  • Unbalanced RCA outputs
  • Variable or preset output level controls, switch selectable
  • Direct connection to powered monitors
  • Built-in Benchmark HPA-2, a high-output, ultra-clean headphone amplifier with dual outputs jacks
  • Total jitter immunity via UltraLock technology!
  • Phase Accurate D/A conversion across any number of channels
  • 1 power, 2 error indicating LEDs
  • Internal low-radiation toroidal power supply
  • International 115-230 input voltage range
  • Automatic De-emphasis for 44.1, 48, 88.2, and 96kHz when Pre-emphasis bit is set
  • Milled aluminum front panel
  • 1/2 wide, 1RU chassis
  • Equipped with non-removable rack ears; call for models without rack ear
[url=
[url=[url=
[url=
laateedoo
Number of posts : 9
Registration date : 2018-08-23
Benchmark DAC 1 Pre 24bit 192Khz Empty Re: Benchmark DAC 1 Pre 24bit 192Khz
Post by laateedoo on Tue Nov 19, 2019 8:49 am
laateedoo
Number of posts : 9
Post by laateedoo on Tue Nov 26, 2019 1:23 am
laateedoo
Number of posts : 9
Post by laateedoo on Wed Dec 04, 2019 2:12 pm
laateedoo
Number of posts : 9
Post by laateedoo on Thu Dec 05, 2019 2:20 am
laateedoo
Number of posts : 9
Post by laateedoo on Sat Dec 28, 2019 7:49 am
laateedoo
Number of posts : 9
Post by laateedoo on Tue Jan 21, 2020 1:30 pm
BUMP!
laateedoo
Number of posts : 9
