Klipsch PRO-250RPW In-Wall LCR Speaker ( Each )
Klipsch PRO-250RPW In-Wall LCR Speaker ( Each ) Empty Klipsch PRO-250RPW In-Wall LCR Speaker ( Each )
Post by stylelaser.com.my on Sat Nov 30, 2019 12:34 pm
Klipsch PRO-250RPW In-Wall LCR Speaker ( Each ) Brand New. Now Selling At RM1,799. Free Shipping Within West Malaysia.
PRO-250RPW LCR
          [You must be registered and logged in to see this link.]          [You must be registered and logged in to see this link.]
Dual 5.25” In-Wall LCR Speaker
TRUE REFERENCE PREMIERE ACOUSTICS
Using the same acoustic components and horn material as the highly acclaimed Reference Premiere box speaker line, the Professional Reference Premiere Architectural series perfectly combines the aesthetics of an architectural speaker with the pure performance and dynamic voicing of the Reference Premiere series. With two 5.25” Cerametallic woofers and a 1” Titanium Dome tweeter mated to a composite coated Hybrid Cross Section Tractrix® horn, the Pro-250RPW LCR brings dynamic, powerful, detailed Reference Premiere sound to your home theater system.
SECUREFIT™ INSTALLATION SYSTEM
The exclusive modular installation system allows for the dog legs to be engaged by hand to a preset clamping force, eliminating the possibility of overtorquing, which can lead to breaking the dog leg or cracking the drywall. The speaker module is then screwed to the bezel (using machine screws instead of traditional drywall screws) for a more robust, acoustically stable installation than the competition.
ALL NEW, BEZEL-FREE MAGNETIC GRILLE
A completely redesigned powercoated magnetic steel grille eliminates the bezel for seamless, pristine integration into the living space.
PVC PAINT SHIELD INCLUDED
Also included is a magnetic PVC paint shield that can be used to cover the speaker module to protect it from paint or construction dust during renovations or remodels.
Peter  012-2536225
Fong   016-3098668
Klipsch PRO-250RPW In-Wall LCR Speaker ( Each ) Trade
SPECIFICATION
FREQUENCY RANGE 46Hz - 23kHz +/- 3dB
HIGH FREQUENCY DRIVER 1" (2.54cm) Titanium Dome Tweeter mated to a composite
coated Hybrid Cross Section Tractrix® Horn
LOW FREQUENCY DRIVER Dual 5.25" (13.34cm) Cerametallic Woofers
SENSITIVITY 94 dB @ 2.83V / 1m
COVERAGE ANGLE 90° x 90°
POWER HANDLING 75W RMS / 300W Peak
IMPEDANCE 8 Ohm Compatible
ENCLOSURE MATERIAL/TYPE ABS/Infinite Baffle
FINISH Black Baffle/Frame, White Paintable Grille
PRODUCT DIMENSIONS 7.5” W x 17.4” H x 3.8” D (19.1cm H x 44.2cm W x 9.6cm D)
MOUNTING DEPTH 3.78” (9.35cm)
CUTOUT DIMENSIONS 16.5” H X 6.5” W (41.9cm H X 16.5cm W)
PRODUCT WEIGHT 6.5lbs (2.95kg)
INCLUDED IN BOX Grille, Paint Shield
INSTALL KIT IK-502-W (Sold Separately)
Number of posts : 657
