Audio Pro Complete 5.1 Speaker System + Marantz SR4500
Audio Pro Complete 5.1 Speaker System + Marantz SR4500 Empty Audio Pro Complete 5.1 Speaker System + Marantz SR4500
Post by sindhikid on Tue Dec 03, 2019 10:34 pm
Moving to a sound bar and letting go of this loved set, all in perfect working condition with minor surface wear and tear.
Selling the whole set 5 Speakers + Subwofer + Amplifier for RM1,500 nego
Audio Pro Complete 5.1 Speaker System + Marantz SR4500 Speake12Audio Pro Complete 5.1 Speaker System + Marantz SR4500 Subwof12Audio Pro Complete 5.1 Speaker System + Marantz SR4500 Marant13
https://www.soundandvision.com/receivers/205marantz
The Cinema Room system is a complete voice matched Home Theatre speaker system. Five identical C1 satellites handle front, centre and surround information whilst the Ace-Bass Cinema Sub handles all low frequency and LFE information.
The diminutive Cinema C1 is a versatile loudspeaker equally suited to wall or shelf placement. A dedicated centre channel version of the C1 includes a step-less mounting cradle allowing the speaker to be angled either up or down towards the listening area.
As the foundation of the Cinema Room System the Cinema Sub is an exceptional unit in several regards with its small size giving no clues as to the performance on offer. Ultra compact wall brackets are included with both front and surround pairs enabling a choice of mounting arrangements.
SPECIFICATIONS.
Overview:
Complete 5.1 Voice Matched Speaker System
Applications:
Discrete Home Theatre Installations
C1 Driver Array:
Two Way / Two Drivers
Driver Design:
HF 1 x 25mmSoft Dome Tweeter LF 1 x 87.5mm Composite Woofer
Cinema Sub Driver Array:
Single Driver Long Throw
Amplifier Section:
Output power: 75W rms Ace-Bass Design
System Response:
30 Hz – 20 kHz +/- 3 dB
C1 Sensitivity:
87 dB @ 1m
Impedance:
8 Ohm (Nominal)
C1 Placement: Wall Mounted (Bracket Included) Shelf Mounted Pedestal Cradle (Included)
Features:
Full Magnetic Shielding Multi-Angle Wall Brackets Included
Dimensions:
C1 Speakers:
W 11cm x H 15cm x D 16cm
Cinema Sub:
W 24cm x H 29cm x D 30cm
sindhikid
Number of posts : 1
