Acoustic Energy (sold)
ACOUSTIC ENERGY AEGIS EVO 3 SPEAKERS
The Aegis three is the flagship of the Aegis series. A 3-way, slim-line, floor-standing loudspeaker using the award-winning tweeter and metal alloy mid/bass driver system design from the Aegis one, and two, with the addition of a new 180mm vented polymer chassis with a polypropylene cone for the bass only drive unit.
The mid/bass driver is reflex loaded through a flared port to the rear, whilst the bass only unit is a housed within a separate enclosure and reflex loaded through a high powered flared port to the front. Factory -fitted mass loading is supplied in the base of the cabinet, in addition to a base plinth and 8mm spikes for optimum stability and coupling to the floor.
The result of this impressive flagship system offers the discerning listener ownership of a product with awesome scale and depth, coupled with a level of detail and clarity unequaled by any other loudspeaker at the price.
Using a newly developed, LF 130mm high efficiency metal alloy mid/bass drive unit and the 25mm Ferro fluid cooled HF silk dome tweeter which are magnetically shielded makes this an ideal AV speaker with exquisite transparency, detail and clarity, awesome bass punch and dynamics coupled with high end efficiency and compatibility.
Extended frequency response of 33 Hz to 22 kHz
Terminals: Gold-plated plated bi-wireable binding posts
Power Handling: 150 watt max
Magnetically shielded
Frequency Response at 3dB
33 to 22kHz
Sensitivity SPL/m/2.83V
90dB
Dimensions (HxWxD) in mm
192x880x220
Maximum Power Handling
150 watts
Termination
Gold Plated Bi-wireable
HF Driver
19mm silk fabric dome
LF Driver
130mm chassis,
Enclosure Type
High power, bass-reflex port.
Nominal Impedance
8 Ohm
Weight 16Kg
- Number of posts : 2967
Up
Up
Up
» Acoustic Energy AE2 ( sold)
» Acoustic Energy AE1(used)(SOLD)
» Acoustic energy Sold
» Acoustic energy SOLD
» Acoustic Energy AE1(used)sold
