Onkyo A-9911 Integrated Stereo Amplifier
Onkyo A-9911 Integrated Stereo Amplifier Empty Onkyo A-9911 Integrated Stereo Amplifier
Post by khorht on Thu Jan 02, 2020 12:23 pm
Selling my used Onkyo A-9911 Integrated Stereo Amplifier.
This was one of "Onkyo's best integrated amps" using the finest parts and "No-Compromise Engineering" approach., this amp at 90 WPC, has incredible build quality in and out. Everything is built with Audiophile components in mind including the ATR Audio Tuned Reference Capacitors, Twin Core AEI Transformers, "Two" Large ELNA HI-FI Capacitors 15000uF each, 4 - Gang Master Volume Control, Twin Aluminum Heat Sinks and the Double Thickness of Copper Traces on the 70 micron PC Board.
Power output: 90 watts per channel into 8Ω (stereo)
Frequency response: 2Hz to 50kHz
Total harmonic distortion: 0.06%
Damping factor: 130
Input sensitivity: 0.3mV (MC), 3mV (MM), 300mV (line)
Signal to noise ratio: 70dB (MC), 87dB (MM), 105dB (line)
Output: 300mV (line)
Voltage: 240 VAC
Frequency: 50 - 60 Hz
Dimensions: 435 x 165 x 444mm
Weight: 19.7kg
Condition: 7/10
Color: Gold
Price: RM1080 Nego...
Kindly contact Khor 019-7711673 via whatsapp or call.
Onkyo A-9911 Integrated Stereo Amplifier Img_2041
Onkyo A-9911 Integrated Stereo Amplifier Img_2040
khorht
Club Member
Club Member
Number of posts : 27
Registration date : 2017-04-10
Onkyo A-9911 Integrated Stereo Amplifier Empty Re: Onkyo A-9911 Integrated Stereo Amplifier
Post by khorht on Thu Jan 16, 2020 9:15 pm
Available...  Smile
khorht
Club Member
Club Member
