TAG McLaren Audio F3 Series 60I SL England Made Stereo Integrated Ampifier
TAG McLaren Audio F3 Series 60I SL England Made Stereo Integrated Ampifier Empty TAG McLaren Audio F3 Series 60I SL England Made Stereo Integrated Ampifier
Post by HiFiLab on Thu Feb 06, 2020 10:26 pm
TAG McLaren Audio F3 Series 60I SL England Made Stereo Integrated Ampifier 20171214
TAG McLaren Audio F3 Series 60I SL England Made Stereo Integrated Ampifier 20171215
TAG McLaren Audio F3 Series 60I SL England Made Stereo Integrated Ampifier 20171216
TAG McLaren Audio F3 Series 60I SL England Made Stereo Integrated Ampifier 20171217
TAG McLaren Audio F3 Series 60I SL England Made Stereo Integrated Ampifier 20171218
TAG McLaren Audio F3 Series 60I SL England Made Stereo Integrated Ampifier 20171219
Made In England
Price : RM 1650
key features
•'Straight Line Technology'
• feedback paths Versatile integrated amplifier, with relay-switched, independent
• preamplifier and power amplifier sections, giving a future-proof upgrade path to higher-grade separates High-quality audio components
• Rated 60 W, typically 72 W into 8
• typ. 115 W into 4 and rated 130 W, typ. 150 W into 2 short periods) Mains supply interrupt monitor
• Class A preamplifier stage
• Direct input to power amplifier section
• Six line level inputs for: CD, tuner, auxiliary, and three tape
• recorders Independent input selection for listening and tape recording
Two pairs of loudspeaker terminals • One low-impedance stereo outputs from preamplifier to allow
• long cable runs
Three stereo outputs for recording
• Headphone output for a wide range of impedances with
• automatic muting when headphones are plugged in Volume control and input selector can be operated manually or
•  ® sonic isolation feet, specially designed by
• TAG McLaren Audio
Note :  For the very best performance we recommend that our units are placed on individual shelves and are not stacked one on top of another
Future-proof
The 60I SL is future-proof. It is the perfect amplifier if you want to upgrade your audio system at a later stage.
The 60I SL circuitry can easily be split into its separate preamplifier and power amplifier sections, allowing you to use higher-grade component units, such as our preamplifier PA20R or our stereo amplifier 100P.
Even bi-amping, using an amplifier such as our 60P or 100P, becomes a straightforward upgrade.
welcome The 60I SL combines the convenience of an integrated amplifier with the versatility to easily upgrade to separates at a later stage.
HiFiLab
Number of posts : 2649
