Monitor Audio Bookshelf Speaker (Sold)
Monitor Audio Bookshelf Speaker (Sold) Empty Monitor Audio Bookshelf Speaker (Sold)
Post by Leong222 on Sat Feb 08, 2020 6:02 pm
Brand      :Monitor Audio
Model      :Gold 50
Colour     :Walnut
Type        :Bookshelf Speaker
Condition : 8/10
Price        : Sold
Contact    :012 5020 182 (leong)
Monitor Audio Bookshelf Speaker (Sold) Img_7319
Monitor Audio Bookshelf Speaker (Sold) Img_7320
Monitor Audio Bookshelf Speaker (Sold) Img_7321
The sculpted low-diffraction cabinet of the Gold 50 houses a single 5.5" RST bass driver and C-CAM ribbon.
The bass driver exhibits the low frequency extension and power handling of a much larger transducer while the excellent C-CAM ribbon soars beyond conventional tweeter domes to a stratospheric 60 kHz. Consequently the Gold 50 combines the frequency range of the finest studio monitors with dynamics that defy its modest dimensions.
Optional, dedicated floor stands are available, which can be filled to provide the ultimate foundation for the best possible sound quality.
 Technology
  • C-CAM (Ceramic-Coated Aluminium/Magnesium) ribbon transducer design – providing extension to a class leading 60 kHz
  • HiVe II port technology for better transient response and tighter bass
  • C-CAM RST (Rigid Surface Technology) bass/mid-range driver
  • Single bolt through driver fixings for improved bracing, rigidity and driver/baffle de-coupling
  • Die-cast alloy terminal panel arrangement with high quality bi-wire terminals and high end spade type link cables
  • Pureflow Silver internal cabling
  • Selected premium quality wood veneer or high gloss lacquer finishes
  • Rigid 20 mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet colouration
  • Invisible magnetic grille fixing provides clean visual styling when used with the grille off.
Last edited by Leong222 on Fri Feb 14, 2020 2:06 pm; edited 1 time in total (Reason for editing : Sold)
Leong222
Number of posts : 349
