Klipsch KG 3.5 USA Made Horn tweeter floorstand speaker
Klipsch KG 3.5 USA Made Horn tweeter floorstand speaker Empty Klipsch KG 3.5 USA Made Horn tweeter floorstand speaker
Post by HiFiLab on Sat Feb 15, 2020 7:11 pm
Klipsch KG 3.5 USA Made Horn tweeter floorstand speaker 20200173
Klipsch KG 3.5 USA Made Horn tweeter floorstand speaker 20200174
Klipsch KG 3.5 USA Made Horn tweeter floorstand speaker 20200175
Klipsch KG 3.5 USA Made Horn tweeter floorstand speaker 20200176
Klipsch KG 3.5 USA Made Horn tweeter floorstand speaker 20200177
Made In USA
Price : RM 1250
Very good sound!!!
FREQUENCY RESPONSE:
36Hz-20kHz(+-)3dB
HIGH FREQUENCY HORN:
90(o)x40(o) Exponential Horn
NOMINAL IMPEDANCE:
8 ohms
POWER HANDLING:
65 watts maximum continuous (325 watts peak)
SENSITIVITY:
94dB @ 1watt/1meter
TWEETER:
K-84-K 1" (2.54cm) Polymer dome compression driver
WEIGHT:
39 lbs. (17.7kg)
DIMENSIONS:
33.5" (85.1cm) x 10.5" (26.7cm) x 11.5" (29.2cm)
ENCLOSURE TYPE:
Bass reflex via front-mounted port
HiFiLab
Number of posts : 2651
