Can u use a pre amp with the cambridge audio 640a v2?
Page 1 of 1 • Share •
Hi guys,
as the topic states, is it possible to use a pre amp with the cambridge audio 640a v2? by doing this, will it improve sound quality by pairing the CA 640A v2 with a tube amp?
thanks in advance..
thanks in advance..
wrexican- New Member
Number of posts: 20
Registration date: 2009-10-02
Re: Can u use a pre amp with the cambridge audio 640a v2?
if it has inputs for an outboard preamp (will be marked preamp in), then you can. As for any sonic improvement, it all depends on how they match up ...
bassraptor- Moderator
Number of posts: 711
Registration date: 2009-01-17
Source(s): LP/CD/Streamer
Amplification: Yes
Speakers: Yes
If u don't like the sound of your cambridge, u could be better off looking for another amp more suitable for your needs. I think it's a better bet. A more far out solution would be to mod your present amp, but that's a specialist job, unless u could diyed at your own time and expertise.
Number of posts: 368
Registration date: 2009-09-07
There is no easy way to bypass the pre-amp and volume pot of the 640a since there is no direct input at the back to the power amp section.
We could perhaps crank the 640a's volume all the way to the max to sort of bypass it (not entirely). The input impedance is 47kohm so any pre-amp with output impedance no more than 470ohm should work. Passive pre's with 10k/50k/100k pots won't be ideal.
f8.- Regular
Number of posts: 53
Registration date: 2009-04-05
thanks for that...do u guys have any tube preamps that u wanna recommend? something not too expensive, the cheaper the better i guess...
Number of posts: 20
Similar topics» Collins Easy Learning Japanese Audio Course
» Cambridge Audio 640A V2 (Used) Sold
» Cambridge Audio Azur 540A amplifier for sale
» The new Cambridge Audio ranges
» Cambridge Audio 640P (sold)
» Sonus Faber Solo center speaker (Used)
» creek passive pre + bel canto power amp
» CYRUS TUNER & CD PLAYER
» Wts Tara lab speaker cable (very cheap)
» Proac Studio 150 (used)
» Jadis DA60 Integrated Amp (Used)
» Electrocompaniet emc-1 (used)
» Van Den Hul 'Mainsstream BS' Power Cord - 2m (Used)
» Crystal Cable Piccolo Interconnects - 0.5m pair (Used)
