Does room contribute to sound "warmth" and "coldness"??
Post by THT89 on Tue Jun 29, 2010 6:25 pm
Dear all,
Does anyone have any documents/experience regarding room structure/treatments affecting the "warmness" and "coldness" of sound played, either by hi fi or instruments?
Idea
THT89
Club Member
Club Member
Male Number of posts: 40
Registration date: 2009-09-03
Re: Does room contribute to sound "warmth" and "coldness"??
Post by tanbotak on Tue Jun 29, 2010 7:03 pm
RT60 will help u ..
tanbotak
Male Number of posts: 8
Registration date: 2010-04-01
Post by THT89 on Tue Jun 29, 2010 7:53 pm
That means, warmness is partially related to reverberation?
THT89
Club Member
Club Member
Post by uncle_vic on Wed Jun 30, 2010 12:48 pm
Warm sound in a nice listening room?
I gather this much after reading from the link below :"A full or warm sound comes from a system that reproduces low
frequencies well"
http://electronics.howstuffworks.com/digital-versus-analog.htm/printable
So does that mean if u take care/do a good job of the bass reproduction in your listening room........u get that "Warmth"?! Bass traps, and panels, treated wall surfaces to get the bass sounding right.........but it's a very difficult task right?
uncle_vic
Male Number of posts: 368
Registration date: 2009-09-07
Post by uncle_vic on Wed Jun 30, 2010 1:02 pm
Looks like the room u will/are using will determine the amount and kind of bass u are getting and consequently the amount of warmth u are seeking to find..........
"Every room has acoustic characteristics.
The
amount of bass tones is set by the
dimensions. Size matters. Big rooms provide base. There is also a
distance from the speaker to the
listener where the direct speech and the reflected sound arrive at the
same
time. In acoustics, this is known as the Critical Distance."
http://www.writersservices.com/audio/your_studio.htm
uncle_vic
Post by samn on Wed Jun 30, 2010 1:20 pm
Very informative and thoughtful readings. Thanks.
samn
Male Number of posts: 110
Registration date: 2009-02-15
Post by uncle_vic on Wed Jun 30, 2010 4:59 pm
http://www.decware.com/acroom.htm
uncle_vic
Post by tycham on Wed Jun 30, 2010 5:30 pm
uncle_vic wrote:[b]Looks like the room u will/are using will determine the amount and kind of bass u are getting and consequently the amount of warmth u are seeking to find..........
Not totally true. Source and amplification matter more.
http://www.audioasylum.com/forums/pcaudio/messages/4/43510.html
In Reply to: RE: rebirth of the Juli@ posted by Tarkowsky on January 10, 2009 at 12:13:02
"The room itself plays a minor role, because there is so much ambiance present, that it dominates the listening room".
"Good point. I have this experience too"
uncle_vic wrote:
" There is also a
same
time. In acoustics, this is known as the [b]Critical Distance."
How does this affect the warmth or coldness of the sound? How much elapse time is acceptable for the reflected sound to arrive after the direct sound?
Please enlighten.
Regards
tycham
Male Number of posts: 720
Registration date: 2009-02-26
Source(s): Digital
Amplification: Solid State
Speakers: Bookshelf
Post by catal2002 on Wed Jun 30, 2010 6:32 pm
Put a heater, it will be warmer...ha!Jokes aside, i do agreed with tycham. i do find it Source , amplification and wire contribute more.
KLau
www.h1f1.blogspot.com
uncle_vic wrote:
" There is also a
same
Please enlighten.
Regards
catal2002
Club Member
Club Member
Male Number of posts: 35
Registration date: 2009-03-05
Post by uncle_vic on Wed Jun 30, 2010 7:52 pm
tycham, u forgot this part...."A full or warm sound comes from a system that reproduces low frequencies
well" ............then after u keep the bass in its 'good form'! Sometimes we may want to play around with the bass contents and mess things up with some not so suitable room treatments and wrong placements of tube traps, and spoil whatever we have already have.
uncle_vic
Post by tlkoo on Wed Jun 30, 2010 8:55 pm
why not revisit the meaning of warmth in audio sense before further discussion/debate???
http://stason.org/TULARC/entertainment/audio/general/9-14-What-do-they-mean-when-they-say-It-sounds-warm.html
Warm: Good bass, adequate low frequencies, adequate
fundamentals relative to harmonics. Not thin. Also excessive
bass or midbass. Also, pleasantly spacious, with adequate
reverberation at low frequencies. Also see Rich, Round. Warm
highs means sweet highs.
http://www.integracoustics.com/MUG/MUG/bbs/stereophile_audio-glossary.html
warm The same as dark, but less tilted. A certain amount of warmth is a normal part of musical sound.
one talks about bass/midbass while the other doesn't, so which one to follow in further discussions/debates? any golden rule of interpretation one could suggest?
in any case, i just could not agree with the former definition as midrange or high frequency range alone (without bass i.e. below 120hertz) is entitled to sound warm!!! from another perspective, i do not see the need to have well managed low frequency range to sound warm and accordingly i opine that room does not contribute to warmth and coldness
tlkoo
Male Number of posts: 283
Registration date: 2009-05-04
Post by THT89 on Thu Jul 01, 2010 7:10 pm
I had a system, playing in a room with 4 plain walls (square), marble floor, plaster ceiling, a bed.. I found out that it sounded awfully bright. vocal was thin.
Then, the same system, i shifted to another room, smaller in size, rectangular, left side is bookshelf (covering 60%), right & front side plain wall, parquet floor, plain concrete ceiling. Vocal sounds a lot fuller, yet sound stage shrinks.. May caused by the limited separation between left and right speaker.
Let's take this analogy (actually it's a real thing), i'm in a room where it takes around 3 seconds to fully decay my clapping sound. I try to play my bass guitar louder, yet, it becomes so muddy.
But it's still considered warm is it? I find it cold. Perhaps i should get an amp with higher power ratings?
I listened to some chesky's records, found that those very true minimalist pure acoustic performance sounds "colder" if recorded from cathedral, but sounds "warmer" in restaurant/lounge.....!?
THT89
Club Member
Club Member
Post by uncle_vic on Fri Jul 02, 2010 9:04 am
TY Cham, 1st thing one has to get the bass to come out from the equipments..........eg. can't expect bookshelfs to do lots of bass contents.........big floorstanders may do more bass contents than bookshelfs.......and floorstanders with 1 subwoofer obviously slightly more (if tuning is not overkill la).........and with more subwoofers (it's hard to imagine how overkilll one wants to get).........then the room treatments will help......the furnitures such as the soft chair(s) obviously one caters for more than 1 visitors once in a while la......the curtains over the windows.........however small piece of carpet one wants to place on the floor.....It's all about affoding some degree of control of the bass contents........one might get to what one wants.......again depends on one's requirements........there will always be bookshelf owners who will always insist he has all the bass he ever needed....and there are others who will insist his musical diets has got to have those body massage bass contents.......
uncle_vic
Post by tycham on Fri Jul 02, 2010 9:36 am
@uncle_vic
Having said so much (mostly irrelevant stuff) you have yet to answer my question on the effect of critical distance and the acceptable elapse time between direct sound and reflected sound.
If you don't know or doesn't want to answer, please indicate so.
tycham
Source(s): Digital
Speakers: Bookshelf
Post by tlkoo on Fri Jul 02, 2010 10:22 am
hoi uncle... why are you disregarding the latter definition of "warmth" which is quiet on bass??? no bass not warmth??? betul kah?
uncle_vic wrote:TY Cham, 1st thing one has to get the bass to come out from the equipments..........eg. can't expect bookshelfs to do lots of bass contents.........big floorstanders may do more bass contents than bookshelfs.......and floorstanders with 1 subwoofer obviously slightly more (if tuning is not overkill la).........and with more subwoofers (it's hard to imagine how overkilll one wants to get).........then the room treatments will help......the furnitures such as the soft chair(s) obviously one caters for more than 1 visitors once in a while la......the curtains over the windows.........however small piece of carpet one wants to place on the floor.....It's all about affoding some degree of control of the bass contents........one might get to what one wants.......again depends on one's requirements........there will always be bookshelf owners who will always insist he has all the bass he ever needed....and there are others who will insist his musical diets has got to have those body massage bass contents.......
tlkoo
Post by tlkoo on Fri Jul 02, 2010 12:06 pm
hi tht89
are you "miss-taking" reverberations and reflections as "warmth"?
care to bring your familiar pieces/albums to audition with other setups???
sound to fully decay in 3 seconds??? which means very very much overlaps of sound when any piece of music is played back eh does bass linger on even longer? how to enjoy music in such room? ask for auditions with other setups mate!
good luck
tlkoo
tlkoo
Post by uncle_vic on Fri Jul 02, 2010 12:24 pm
I know I talk alot and also being the messenger of 'messages that people don't like to read'!!!
But I have a systems to let others listen to when they asked, tho I don't care to invite, but welcome those who are interested to know more about what i do with hifi pursuits besides just talking!
uncle_vic
Post by THT89 on Fri Jul 02, 2010 11:13 pm
tlkoo wrote:hi tht89
I think i didn't. Just that, personally, i feel that a room with 4 plain hard cold walls, just like medieval cathedrals sounds very cold.. Even if an organ is played. Or is that just my personal view? I'm confused, and think that they are related. And this is my current main concern! Reverb vs Warmth
Well, ya lor, 3 second wor! Actually (sorry!) it's not a hi fi room, it's a hall, where by i played my band there. I hope to get some idea on concept of warmth. But, seems like, when a room is having 3 sec reverb decay time, what sort of good system will sound awful too? But, will it be the cause for it to sound "thin"?
Personally (again.. lack of knowledge!!) i "feel" that, warmth is the fluidity of the midrange. Also, once i read that if one wants to get fullness of vocal, it would be essential to enhance 250Hz. But this is an aid for cheap live reproduction la.
But, up to certain degree, i agree with the treatment. Coz my "hall" doesn't control the bass well. If put carpets, it should sound better!
Try imagine: If a room acoustic condition (different degree of absorbing characteristic of different walls/treatments) causes a 4 sec reverb decaying time for 250Hz.. It'd sound a lot.... warm??!
At least my answer is: If can't control mid bass, don't ever think of getting warm sound, only if you can tahan something like "low bass lack, mid bass awesomely loud, mid lack, high and air abundant!!..." it sounded thin to me.
Mad
THT89
Club Member
Club Member
Post by tycham on Sat Jul 03, 2010 9:37 am
uncle_vic wrote:I know I talk alot and also being the messenger of 'messages that people don't like to read'!!!
Reflect on this.
"I think everyone's goal should not be to kill the messenger, he's already made up his mind and it's unlikely any rational thought will convince him otherwise, but to prevent the uncontested spread of misinformation."
Anon.
tycham
Source(s): Digital
Speakers: Bookshelf
Post by tlkoo on Sat Jul 03, 2010 3:32 pm
since you insist to have your own definition of "warmth" i just have to wish you good luck
tlkoo
Post by THT89 on Sun Jul 04, 2010 12:58 am
But if it's not related to reverb, then..
adequate reverberation...
THT89
Club Member
Club Member
Post by tlkoo on Sun Jul 04, 2010 8:50 am
check your definition against this one as you have "re-quoted" though i have chosen to agree with the latter as i perceive warmth even in the absence of bass pardon me for not being able to answer your questions
tlkoo
Post by uncle_vic on Wed Sep 15, 2010 1:04 pm
I walk the talk.....leh...........nevermind if people say i talk too much........at least i have my work to show la.................... Very Happy
http://h1f1.blogspot.com/2010/09/my-room-acoustics.html
uncle_vic
Post by dheensay on Wed Sep 15, 2010 4:13 pm
Have any of you heard music being played in a hall?
Allow me to suggest that :
A choir performing on a LOOP PILE carpeted stage with 2x4 structural support in a hall 130'x85' with wall panels
1. A choir
2. performing "esther" on a
3. LOOP PILE carpeted
4. 3' stage with
5. 2x4 structural support in a
6. hall
7. 130'x85' with
8. wall panels
Each of the numbers listed above is a variable. Each variable changes the perception we have of the performance. Do you agree? If we change just one variable, what becomes of the sound we hear?
Now if i change JUST ONE VARIABLE :
An orchestra performing "esther" on a WOOL CARPETED 3' stage with 2x4 structural supposet in a hall 130'x85' with wall panels
WHAT BECOMES OF THE SOUND?
Now of course - I did not even include the type of PADDING below the carpet - rubber, foam, urethane etc etc. .
The journey of sound is quite amazing. Numbers, definitions, jargon are all very important while trying to get a point across to another person. BUT THE REAL TEST is in the hearing, wouldnt you say?
dheensay
Male Number of posts: 128
Registration date: 2009-01-20
