Klipsch SPL-100 10" Powered Subwoofer (PL)(Sold)
Klipsch SPL-100 10" Powered Subwoofer (PL) Used In Excellent Condition. Now Selling At SOLD. Free Shipping Within West Malaysia.
Features:
Reference Premiere woofers are housed in a non-resonating, stamped-steel basket that’s secured to a large magnet motor for exceptional efficiency and low distortion, and matched to our horn-loaded tweeters for optimal acoustic execution.
Both the RCA and wireless inputs can be utilized, giving you the ability to use a single subwoofer with multiple system in the same room. For example, you can use the wireless input for your home theater set up and the RCA input for your 2-channel system, without needing to switch inputs when changing between systems.
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
FREQUENCY RESPONSE 27Hz - 125Hz
MAXIMUM ACOUSTIC OUTPUT 114dB
AMPLIFIER TYPE Class D with Analog Preamp Stage
AMPLIFIER POWER 200 W RMS / 450 W Peak
WOOFER 10” Long-Throw Cerametallic
ENCLOSURE MATERIAL MDF
ENCLOSURE TYPE Bass Reflex via Front-Firing Slot Port
INPUTS Dual RCA/LFE Line In, WA-2 Wireless Port
HEIGHT 16-9/16” (421mm)
WIDTH 14” (356mm)
DEPTH 17-5/16” (451mm)
WEIGHT 37 lbs (16.8kg)
FINISH Ebony Vinyl
BUILT FROM 2018
Klipsch SPL-100
Leveraging a 10" spun copper Cerametallic woofer and high-efficiency Class-D amplifier, The Klipsch SPL-100 subwoofer delivers best-in-class low frequency output.Features:
- 10" Spun Copper Cerametallic Woofers
- Bass-Reflex via Exclusive Front-Firing Internal-Flare Port
- Class D Amplifier with 200W RMS / 450W Peak
- Premium Scratch-Resistant Finish
- Strong, Flexible Removable Magnetic Grille
- Dimensions: 16.5” x 14” x 17.3”
HIGH EFFICIENCY CLASS D AMPLIFIER
The built-in, high efficiency amplifier features an analog preamp design, which maintains the original signal path for cleaner, true-to-source reproduction. The Class D output stage ensures maximum efficiency for maximum output, detail, and low frequency power.SPUN COPPER CERAMETALLIC WOOFERS
Cerametallic woofers are exceptionally light and extremely rigid, providing remarkable low frequency response with minimal cone breakup and distortion for higher, cleaner output using less amplifier power.WOOFER ANATOMY
Klipsch Cerametallic cones are matted to a dual-layer, copper-wound voice coil for exceptional conductivity.Reference Premiere woofers are housed in a non-resonating, stamped-steel basket that’s secured to a large magnet motor for exceptional efficiency and low distortion, and matched to our horn-loaded tweeters for optimal acoustic execution.
EXCLUSIVE PORT TECHNOLOGY
Klipsch SPL subwoofers leverages proprietary internal-flare geometry that minimizes port noise for clean undistorted low frequencies. The front-firing design allows for placement flexibility to reduce unwanted resonance from your walls or furniture behind the subwoofer.TAKE CONTROL
Low Pass Crossover and Variable Phase control allows you to tune the subwoofer to your Klipsch speakers and to your room, establishing the ideal level of bass. Line Level / LFE RCA inputs ensure compatibility with home theater receivers.Both the RCA and wireless inputs can be utilized, giving you the ability to use a single subwoofer with multiple system in the same room. For example, you can use the wireless input for your home theater set up and the RCA input for your 2-channel system, without needing to switch inputs when changing between systems.
ULTRA-DURABLE DESIGN
Klispsch SPL subwoofers feature a scratch resistant ebony finish that looks like real wood and covers the entire cabinet. Shock-absorbing rubber feet, steel grille posts and a woven cloth grille give the SPL subwoofers a premium look and feel.Interested please feel free to contact:
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
WIDTH 14” (356mm)
FINISH Ebony Vinyl
BUILT FROM 2018
www.stylelaser.com.my
- Number of posts : 1342
» Klipsch KSW-50 powered subwoofer (sold)
» Klipsch SW-115 Powered Subwoofer (used) SOLD
» Klipsch SW-10I Powered Subwoofer (SOLD)
» Klipsch SPL-150 15" Powered Subwoofer (Sold Out)
» Klipsch KSW10 powered subwoofer SOLD
