Marantz HD-CD1 High Definition CD Player (PL) (SOLD)
Marantz HD-CD1 High Definition CD Player (PL) (SOLD) Empty Marantz HD-CD1 High Definition CD Player (PL) (SOLD)
Post by stylelaser.com.my Thu May 16, 2024 11:11 am
Marantz HD-CD1 High Definition CD Player (PL) Used In Excellent Condition. Now Selling At RMSOLD. Free Shipping Within West Malaysia.
Marantz HD-CD1 High Definition CD Player (PL) (SOLD) 1103
HD-CD1
The latest addition to the new Marantz MusicLink series is the HD-CD1, a high-quality CD player in the same compact form as the HD-AMP1 amplifier, for which it is the perfect match. Combining more than 30 years of Marantz expertise in compact disc playback with the latest developments in digital audio technology, it's ideal for use as a CD transport when used with the HD-AMP1, or as a CD player in any situation where a compact form-factor is required without any compromise on sound quality. Small it may be, but it makes use of state-of-the-art Marantz technology carried over from our Award-winning CD players, including a high-resolution 192kHz/24-bit digital-to-analog converter from Cirrus Logic, a high-accuracy system clock, and the famous Marantz HDAM-SA2 amplifier modules, as found in our flagship Reference Series CD players and amplifiers. Selected components are also used throughout the audio signal path, for the very best reproduction of your music. A centralized CD mechanism, able to play MP3, WMA and AAC files as well as standard CDs, is also used for ultra-accurate disc-reading and, along with its analog audio outputs, optical and coaxial digital connections are provided, allowing the HD-CD1 to be connected directly to the HD-AMP1's ultra-high-quality digital-to-analog conversion. The HD-CD1 also features the stylish MusicLink design, with a solid aluminum front panel, double-layer chassis for vibration isolation and retro-style side panels. It also includes a high-quality integral headphone amplifier with adjustable gain to drive high-end headphones for personal listening and comes complete with a remote control for all its functions, also able to 'drive' a complete system of HD-CD1 and HD-AMP1. It's a superb Marantz CD player—in miniature!
HD-CD1是新款马兰士MusicLink系列的最新成员,一款高品质CD播放机,与其完美搭档HD-AMP1放大器具有相同紧凑形状。它将马兰士超过30年的在小型光盘播放领域专业技术和数字音频技术的最新发展结合起来,当配合HD-AMP1使用时是用作CD转盘的理想之选,或在需要外形紧凑而不妥协音质的功率放大器时用作搭配的CD播放机。它个头虽小,但却用上了从我们获奖CD播放机上传承的最先进马兰士技术,包括来自Cirrus Logic的高解析度192kHz/24位数模转换器、高精度系统时钟和著名的马兰士HDAM-SA2放大器模块,这些在我们的旗舰级参考系列CD播放机和放大器中可以找到。整个音频信号路径也都使用了精选元件,为实现音乐的最佳再现。位于中心的CD驱动装置能够播放MP3、WMA和AAC文件以及标准CD,还用于超准确光盘读取,除了模拟音频输出之外,还提供光纤和同轴数字接口,使HD-CD1能直接连接至HD-AMP1的超高品质数模转换器。HD-CD1还具备时尚的MusicLink设计,带实心铝制前面板、双层隔振底盘和复古风格的两侧面板,还包括高品质集成耳机放大器,能调节增益驱动高端耳机进行个人聆听,且附带可调控所有功能的遥控器,还能控制整个HD-CD1和HD-AMP1系统。这是一款超凡的马兰士CD播放机——迷你款!
Marantz HDAM for Superb Audio Performance
Compact the HD-CD1 may be, but at its heart is all the technology that's made Marantz a leader in top-quality CD playback. And central to that is the use of the Marantz-designed HDAM Hyper-Dynamic Amplifier Modules: in place of the all-in-one 'chip amplifiers' used elsewhere, these miniature amplifiers are built from separate, optimized components for the very best sound quality, and are found in Marantz products all the way up to the Reference series players and amplifiers. In the HD-CD1 the latest-generation HDAM-SA2 version of this technology is used, to provide a wide dynamic range and wide frequency response with lowest distortion - in other words, to get you closer to the music. HDAM technology is also used in the headphone section, which has its own dedicated amplification.
带来超凡音频性能的马兰士HDAM
HD-CD1也许有点紧凑,但是其心脏拥有使马兰士成为顶级CD播放领导者的所有技术。而最重要的是使用了马兰士设计的HDAM超级动态放大器模块:取代其他厂家所使用的一体式‘芯片放大器’,这些迷你放大器由独立、优化元件制作,能获得极佳的音质。马兰士一直到参考系列播放机和放大器的所有产品都使用了HDAM。HD-CD1使用了此技术的最新一代HDAM-SA2版本,以最低失真提供宽动态范围和宽频率响应——换句话说,让您更靠近音乐。HDAM技术也在耳机部分使用,并拥有自己的专用放大器。
Reference-Quality Digital-to-Analog Conversion
Central to the sound quality of the HD-CD1 is a high-quality CD transport mechanism, designed for ultra-accurate disc-reading, and this sends data to the player's high-resolution digital-to-analog converter, which is the same Cirrus Logic CS4398 device found in top-flight digital hardware. This is used together with a crystal oscillator master clock designed for ultra-low phase noise, and a low impedance capacitor, also designed for low noise, ensuring digital data is converted into an analog sound with lifelike dynamics and timbre, breathtaking presence and sheer musicality.
基准品质数模转换
对HD-CD1音质至关重要的是高品质CD传送机构,为超准确光盘读取而设计,由它将数据传送到播放机的高解析度数模转换器。此数模转换器即为顶级数字硬件所采用的Cirrus Logic CS4398。与为超低相位噪音设计的晶体振荡器主时钟以及同为低噪音设计的低阻抗电容器一起使用,可确保以逼真的动态和音调、令人惊喜的现场感和犀利的乐感将数码转换成模拟声音。
Dedicated Headphone Amplifier with Volume Control & Adjustable Gain
Whether you want to use the HD-CD1 on your desk for full-time headphone listening, or just occasionally want to connect a pair of 'phones for a private music session, the dedicated headphone section in the player will delight. To make the most of personal listening, it has its own volume control and a dedicated HDAM-SA2 amplifier, complete with adjustable gain setting—low, medium and high—to enable it to drive even highly-demanding audiophile headphones.
带音量控制和可调增益的专用耳机放大器
无论您想要在桌面上使用HD-CD1进行全时耳机聆听,还是偶尔想要连接一对耳机享受一段私人音乐时间,播放机中的专用耳机部分都会令您欣喜。为了充分使用个人聆听,它拥有单独的音量控制和一个专用HDAM-SA2放大器,连同可调节增益设置——低、中和高——使它能够驱动甚至更高要求的发烧友级耳机。
Analog and Digital Outputs
As well as its own high-quality analog outputs, enabling it to be used with any amplifier including the matching HD-AMP1, the HD-CD1 has both optical and coaxial digital outputs, meaning it can be used as a CD transport straight into the digital input on the HD-AMP1 and allowing it to be used with the superb ESS Sabre DAC built into the amplifier. Like the analog outputs, the coaxial digital connection uses a high-quality gold-plated RCA socket, and a digital cable is supplied with the player.
模拟和数字输出
与其所拥有的高品质模拟输出一样,能使其用于包括配套HD-AMP1在内的任何放大器,HD-CD1拥有光纤和同轴数字输出,意味着它可以用作直连HD-AMP1上数字输入的CD转盘,并使它能为放大器中内置的超凡ESS Sabre DAC所用。与模拟输出一样,同轴数字接口使用高品质镀金RCA插座,而且播放机附带数字电缆。
High-current Power Supply & Vibration-Suppressing Chassis
Noise is the enemy of great sound, and the HD-CD1 has extensive measures to suppress both electrical and mechanical interference. A high-current power supply with high-capacity storage capacitors is used to ensure the player is able to deliver the dynamics of music, along with high-speed Schottky Barrier Diodes. The player also has auto-standby and very low power consumption when in standby mode. The HD-CD1 is built on a double layer base-plate for rigidity and vibration suppression, aided by the use of compliant feet, a solid aluminum fascia and a rigid top-plate, and is finished with retro-style side-cheeks for that 'classic Marantz' look.
高电流电源和振动抑制底盘
噪音是音响的公敌,而HD-CD1采用了大量措施以抑制电子和机械干扰。配合高速肖特基二极管,使用了具有高容量存储电容器的高电流电源,以确保播放机能够传播音乐的动力。播放机还具有自动待机功能,待机模式的功耗非常低。HD-CD1建造在双层底板上以确保坚固和抑制振动,辅助使用兼容支脚、实心铝制面板和刚性顶板,两侧以复古风格的装饰,形成‘经典马兰士’外观,提供黑色款式。
System Remote Control
The remote control handset supplied with the HD-CD1 controls all the functions of player, and can also 'drive' the matching HD-AMP1, for simple system integration and convenience.
系统遥控器
HD-CD1附带的遥控器手柄可控制播放机的所有功能,还能控制配套的HD-AMP1,提供简单的系统集成和便利性。
Marantz HD-CD1 High Definition CD Player (PL) (SOLD) 2106
Marantz HD-CD1 High Definition CD Player (PL) (SOLD) Marant10
012-2732555 Hew
016-3098668 John
017-2349074 Rick
012-2536225 Peter
012-2309169 Chris
MONDAY - 10AM-6PM
TUESDAY - 10AM-6PM
THURSDAY - 10AM-6PM
FRIDAY - 10AM-6PM
SATURDAY - 10AM-6PM
Marantz HD-CD1 High Definition CD Player (PL) (SOLD) Trade
Please visit www.stylelaser.com.my to find out more products for sale at very special price..
Features
CD / CD-R/RW / WMA / MP3 / AAC o / o / o / o / o
CD-Text / SA-CD Text / ID3 Tag / WMA Meta Tag / AAC Meta data o / - / o / o / o
Data Disc Compatibility: DSD / WAV / ALAC - / - / -
iPod / iPhone compatible USB input -
DAC operation mode: USB / Coax / Optical - / - / -
Asynchronous mode rear USB -
Bit-perfect transmission -
USB-B DSD Audio Streaming (DoP): DSD2.8 / DSD5.6 -
Signal isolator for DAC Mode operation -
HDAM version SA2
Power Transformer: Toroidal / El - / o
High Grade Audio Components o
Customised Components o
Symmetric circuit layout o
Copper Plated Chassis -
Extra metal plate for chassis strengthing -
Digital out off / Audio EX Mode o / -
Headphone: Standard / Buffer / Current feedback - / o (HDAM-SA2) / -
Mechanism CJDKT690
D/A Conversion Multi-bit, Delta-Sigma
DAC IC CS4398
Digital Filter CS4398
Noise Shaper CS4398
Low Pass Filter stage HDAM
Output Buffer HDAM SA2
Headphone amp HDAM-SA2+Buffer
SA-CD AUDIO
Frequency Response (Cust.) -
Dynamic Range (SA) -
Signal to Noise Ratio (SA) -
Total Harmonic Distortion (SA) -
Channel Separation (SA) -
CDDA AUDIO
Frequency Response 20 Hz - 20 kHz
Dynamic Range 100 dB
Signal to Noise Ratio 110 dB
Total Harmonic Distortion 0.002%
Channel separation 98 dB
Available color: Black o
Metal Front Panel o
Remote Control RC003HD
Power Consumption in W 14
Standby Consumption in W 0.3W or less
Auto Power off o
Detachable Power Cable o
Maximum Dimensions (W x D x H) in inches 12 x 12.3 x 4.3
Weight in lbs 12.6
Number of posts : 1446
