Component pegasus PG166PF TOP MODEL
Component pegasus PG166PF TOP MODEL Empty Component pegasus PG166PF TOP MODEL
Post by zack audio Fri Jun 26, 2009 2:24 pm
Component pegasus PG166PF TOP MODEL Pg166p10Model :PG166PF
Type :6.5" (16cm) Kelvar Cone 2-way Component
System
Features
- Soft and Detailed Sound from Aluminium Case Silk
Dome Tweeter
- Rigid 6.5" (16cm) Double-layer Kelvar Cone
- Well Matching Aluminium Case 2-way 12dB/Octave
Passive Crossover
- Solid Wooden Box Packing
Power Rating : 75 Watts RMS, 150 Watts Peak
Frequency Response : 40 - 20K Hz
Sensitivity : 88dB (1W/1M)
Impedance : 4 Ohm
Crossover : 3.5K Hz at 12dB/Octave, with 0, -3dB
and -6dB selectable attenuation circuit
Woofer : 6.5" (16cm) Double Layers Kelvar Cone,
1.2" (30mm) Ribbon Wire Kapton Voice Coil
Tweeter : 1" Silk Dome, Aluminium Body, 25mm
Kapton Voice Coil, Neodymium Magnet
Master Pack Quantity : 1 Set / Carton
Barang baru,ada warranty...
COD:tesco ampang,tmn.melawati,kepong,sri
damansara,gombak,sg.buloh & kota damansara.
harga terbaik dr ladang.....
RM1500 (MARKET RM2200)
#kalau nak tengok barang audio yang lain
tengok dekat zackaudio.blogspot.com#
ZACK AUDIO
012-2127016
Component pegasus PG166PF TOP MODEL Pg166p11
zack audio
Number of posts : 5
Registration date : 2009-06-26
