[WTS] Alpine H701 Processor, C701 Controller & Optical Cable
[WTS] Alpine H701 Processor, C701 Controller & Optical Cable Empty [WTS] Alpine H701 Processor, C701 Controller & Optical Cable
Post by Xai-V-iaX Sat Jun 09, 2012 10:09 pm
Item(s): As attached below
Price: As stated below
Dealing method: Prefer COD (KL, Damansara, Kelana Jaya, Subang Jaya, Sunway, Bandar Utama & PJ Area)
Contact method/details: 012-21 363 07
Item(s) conditions: ITEMS ARE IN PERFECT AND MINT.
1- Alpine PXA-H701 + Alpine RUX-C701 - SOLD!!! SOLD!!! SOLD!!! [WTS] Alpine H701 Processor, C701 Controller & Optical Cable Thumbup
2- MONSTER THXI100F0 Optical Cable (1M) - RM200 [WTS] Alpine H701 Processor, C701 Controller & Optical Cable Thumbup
Take Both = Awesome Possum PRICE !!! [WTS] Alpine H701 Processor, C701 Controller & Optical Cable Icon_rolleyes
There's
nothing like the cozy confines of a car to emphasize the thrilling
dynamics of surround sound, and Alpine's PXA-H701 audio processor can
help you experience the impact of multichannel sound in your vehicle.
The
processor features three optical digital inputs, so you can connect
each of your digital video sources with just one cable. The processor
decodes the Dolby® Digital or DTS® signal from your DVDs and sends it to
the external amplifiers that power your front, rear, and center-channel
speakers, plus your subwoofer. The PXA-H701 even translates your stereo
CDs into vivid multichannel sound.
If you're using the PXA-H701
with a compatible Alpine in-dash DVD player, you can use the player's
touchscreen controls to adjust the system. If you're using the processor
with an outboard DVD player or a non-Alpine in-dash player, you'll need
an optional Alpine controller to make system adjustments.
No
center-channel speaker in your car? The processor can create a "phantom"
center for you, so you hear the dialog in the middle, where the center
channel normally would be. The processor also includes digital time
correction, graphic and parametric equalizers, frequency filters, and
MediaXpander — sonic enhancement features that help you get your movies
and music sounding just right in your vehicle.
Planning
on using the Alpine PXA-H701 sound processor with a non-Alpine in-dash
stereo? The RUX-C701 module controls all of the processor's functions,
allowing you to set your system just the way you want it.
The
control module's large rotary knob, button, and 3" display make tweaking
your processor much easier. You can adjust equalizer settings, improve
the focus of your bass frequencies, change crossover settings to enhance
speaker efficiency, and maximize your Dolby® surround settings. You can
also engage MediaXpander to fill out your sound, and boost the bass
output. The display even gives you a 31-band spectrum analyzer.
You
can use the included microphone to apply time correction settings in
your vehicle so that information from all your speakers hits your ears
at the same time — your music will sound natural and balanced. If you
have an Alpine navigation system plugged into the sound processor, you
can use this module to set the volume of the voice prompts that are
delivered over your speakers.
Installation hardware is included so that you can mount the module in or on your dash or console.
Xai-V-iaX
Xai-V-iaX
Regular
Regular
Number of posts : 67
Registration date : 2009-09-04
