Rare Vintage Sony Compact TA-3060 Power Amplifier
Made In Japan
Sony TA-3060
September
1 9 6 9
1 9 7 2
Half-width SEPP DC amplifier taking from the TA-3120A but pushing it to the limit :
skyrocketing 300Khz frequency response, very high 180 damping factor and 110dB s/n ratio !
Compared to other contemporary home audio amps, the 3060 was true science-fiction.
Inside is big EI transformer, two grey plastic-potted caps and two back-to-back heatsinks each holding a pair of output transistors.
Launched in Canada in july 1970 ; following it would be the TA-3130F (september 1970) and TA-3140F (june 1971).
Then, after the bestselling TA-3200F (november 1972), separates-wise, would be time for the ESII series : TAN-8550, TAN-5550 and TAN-8250.
If the TA-3120 and TA-3120A are very common, the 3060 is much more rare.
Type : DC quasi-complementary symmetry SEPP OTL
Dynamic output : 70W (IHF, 8 Ohm)
Continuous RMS output : 2x 30W (1Khz, 8 Ohm)
Power bandwidth : 6Hz...35Khz
THD : < 0,1% (rated output, 20Hz...20Khz)
< 0,05% (1W output, 20Hz...20Khz)
IMD : < 0,1% (rated output)
< 0,03% (1W output)
Frequency response : 5Hz...300Khz (+0 / -2dB, 1W output)
S/N ratio : 110dB
Residual noise : 0,03µW (8 Ohm)
Damping factor : 160 (16 Ohm, 1Khz)
180 (8 Ohm, 1Khz)
90 (4 Ohm, 1Khz)
Input : 0,9V / 100kOhm (for rated output)
Outputs : 4...16 Ohm
Semiconductors : 18x transistors
7x diodes
PC : 175W (max, USA models)
Dimensions : 22 x 14,9 x 31,6cm
Weight : 5,8kg
List price : 36,800¥ (1969)
This is not an amp that you will see too often. It is from the 1970 era. Power output is rated at 30 watts per channel but it certainly sounds and feels like a whole lot more as it has a really good sized power supply. It has input level controls
It works very well.
Note : Cosmetics are very good considering its age.
These amps have a nice warm, smooth presentation and three dimensional,
Although they don't have that nice tube bloom I prefer,
the TA-3060 has many tube-like qualities like warm tone,
very good frequency extension and good detail.
Price : RM 850
- Number of posts : 2967
» Sony SS-A5 la voce speakers rare vintage
» Vintage SONY SRP-P2070 studio Power Amplifier
» [SOLD] Sony TA-E2000ESD Digital Processing Control Amplifier (Preamplifier), Sony TA-N330ES Power Amplifier, Sony TA-N220 Power Amplifier (All Used) [SOLD]
» SAE Two A7 Integrated Amplifier ( Rare & vintage) Sold
» RARE 1979 Vintage Marantz PM-8 console stereo amplifier
