ANTELOPE AUDIO ZODIAC PLUS & ZODIAC PSU BUNDLE
Item(s): RM 6500 FOR BOTH ANTELOPE AUDIO ZODIAC PLUS (SRP RM11100) & ZODIAC PSU (SRP RM5000) BUNDLE
Choosing Antelope Audio Zodiac means you are taking a big step into a new world of digital sound clarity, where your listening experience will expand with warmth and detail. Connect your PC, Mac, CD player or any other digital source and enjoy sublime performance from the high grade headphone amplifiers or analog outputs to your speakers.
We consider our 64 bit Oven Clock the most important technology in delivering the signature Antelope sound. While interfacing with common digital audio signal sources, Zodiac technology leaps ahead, resulting in pristine audio normally only obtained by professionals. Custom circuit designs handle the digital audio to produce incredible results that have not been seen or heard before.
Great sound is not something that goes out of fashion, so Zodiac is a DAC to be enjoyed for many years to come.
Features
Custom USB chip streams audio up to 96kHz
Antelope Oven Clock for supreme stability
64 bit Acoustically Focused Clocking (AFC)
129dB Dynamic Range
THD+N: 0.0004%
Ultra Linear, Dual Stage Headphone Amps
Accurate Level Display for Main Volume
Connections
2x S/PDIF coaxial Inputs
2x Optical TOSLINK inputs
USB on mini B type connector
Balanced Analog Outputs on XLR
Unbalanced Analog Outputs on RCA
Oven Controlled Clock
Often overlooked, the quality of the clock is extremely important when high quality audio is desired. The clock is housed in a shielded container where the temperature is kept constant, therefore bringing significant benefits to the detail, dynamics and stereo placement of the audio.
64 Bit Technology
Sophisticated 64 bit algorithms allow precise control over our Acoustically Focused Clocking (AFC) and Jitter Management; two critical components to improve audio via clocking. The incoming digital signal is brought to life with this unique 64 bit technology, resulting in smooth and detailed audio whatever the method of digital connectivity.
Antelope Performance USB
Custom implementation of the USB chip leads to extreme audio performance and comprehensive support for your system. There are user selectable modes tailored to suit both Mac and PC; and with a data transfer rate of 480Mbits flawless audio is achieved with native drivers.
Smooth Headphones
Ultra Linear, Dual Stage Headphone Amps deliver smooth sound at both high and low levels. Custom designed for accurate monitoring with a wide range of headphone impedance's. Controlled by a dedicated volume knob.
Cutting-edge design
To preserve the full bit resolution of the DAC, volume adjustment is entirely in the analog domain. Separate analog and digital power supplies eliminate digital cross-talk. This is further enhanced by keeping analog and digital circuits on separate PCB’s. These gold plated boards utilize large internal ground plains, canceling noise and voltage shifts.
Nuts and Bolts
All component decisions for Zodiac are based on a passion to produce something very special - technically, musically and aesthetically. Built with many solid aluminum parts and also very cute on the eye, it will be your pride and joy just like it is our passion.
In the Box
ZODIAC High Definition 192kHz D/A converter
Printed documentation
DC power supply
IEC type power cable
USB cable
Optical TOSLINK cable
VOLTIKUS PSU
A PSU especially designed to fit your Zodiac DAC
Voltikus is a sleek heavy-duty Power Supply Unit (PSU) designed to perfectly match your Zodiac DAC. Carefully tailored to deliver uncompromised power, Voltikus helps Zodiac achieve the punch and sonic richness of deep lows, a full range of mids, and tightly defined highs. This degree of performance is accomplished by incorporating a hefty, custom-wound, electrostatically shielded toroidal transformer followed by a unique concept of three cascaded power regulators.
Unprecedented stability
A precision laser-trimmed voltage reference (LT1021) serves as the backbone of this discrete design, achieving the stability impossible with off-the-shelf voltage regulators. Voltikus is a true engineering breakthrough from Antelope's respected team of high-end audio experts.
-Audiophile grade PSU perfectly matching Zodiac DACs in aesthetics and performance
-Unique multi-stage linear regulator topology achieves vastly superior stability
-Toroidal transformer with custom electrostatic shield suppresses power line disturbances
-Ground/Lift switch helps eliminate hum and buzz caused by ground loops
-Wide (90-250V) input voltage range ensures dependable operation under varying line conditions
-Advanced discrete design dispenses with the need for noisy off-the-shelf voltage regulators
-Robust sturdy construction with custom machined aluminum front panel
Package includes: AS IN ORIGINAL PACKAGE (CABLE,CHARGER ETC)
[b]Price: RM6500 for both (negotiatable) rclxm9.gif rclxm9.gif
[b]Warranty: DIRECT SEND TO MANUFACTURER
[b]Dealing method: COD PENANG, POSTAGE VIA POSLAJU UPON PAYMENT
[b]Location of seller: GELUGOR, PENANG
[b]Contact method/details: WHATSAPP/PM 0164287052
[b]Age of item: 1 AND A HALF YEAR
[b]Item(s) conditions: USED OCCASSIOANLLY, FOR PICTURES YOU CAN WHATSAPP ME PERSONALLY
[b]Reason for sale: BUYING THE AK380 DAP
[/b][/b][/b][/b][/b][/b][/b][/b]
Features
129dB Dynamic Range
THD+N: 0.0004%
Connections
64 Bit Technology
Smooth Headphones
Cutting-edge design
Nuts and Bolts
In the Box
DC power supply
USB cable
VOLTIKUS PSU
rumpleslitskin- New Member
- Number of posts : 1
Registration date : 2015-08-16
» Antelope Audio Zodiac Platinum384 kHZ dsd dac rrp £5000
» Antelope Audio Zodiac+ HD Mastering 192 kHz D/A Converter/ Pre-amp
» Antelope Zodiac+ d/a converter
