Cypress Serious Cinema Home Theater System
Following the successful release of the range we have designed and built a new high end studio monitor is a radical new design delivering greater bandwidth, higher sensitivity with dynamic, yet smooth and open performance, available with dome tweeters.
Areas of improvement have been mid-range sweet detail and a cleaner, faster and more extended bass response. A new studio monitor quality bass driver was designed. It features a special impregnated cone and mid frequencies are tuned by a cap of greater size than standard. This gives the new unit greater mid-range detail along with excellent bass control giving a tighter and more extended response. The active powered two new bass drivers are each loaded through our special floor loading with side vents, this makes the loudspeaker easier to sight and reacts less to surroundings. The active powered two bass units are then seamlessly mated to dome tweeter depending on your preference. With such a large slim floor standing design the sound stage is superb being very large and with pinpoint imagery. Another achievement for this is its ability to create large orchestral works as well as heavy rock music.
Drivers : Two 8” Long Throw Hi Efficiency Drivers, Carbon Fiber Cone with Rubber, Surround.
Amplifier : Discrete Linear Class A/B Amplifier
Power Output : 250 watts Dynamic Power
Frequency Response : 20 Hz to 270 Hz, 6 dB (LPF@Max)
Low Pass Filter : 60 Hz to 125 Hz, 24 dB/Octave (Continue Variable)
Phase Switch : 180 degree Phase Switch (Standby Operation: Auto On/Off Switch)
Peak Outputs (SPL) : 103 dB
Inputs
High Level (Speaker) : Left & Right High Level Speaker Wire
Low Level (RCA) : Left & Right Low Level RCA Jack
Throughputs
Pressure Clip Terminal : Left & Right High Level Unity Gain
RCA Line Jack : Left & Right Low Level RCA Jack
Unit Dimension : 380mm x 280mm x 760mm (15” x 11” x 30”)
Weight Net/Gross : Net 41 lbs. / Gross 44 lbs.
Cabinet Finish : Masa Maple
Power Requirement : 120VAC 60Hz 250 Max
Remark : Entire System Magnetically Shielded
- Conditin 9/10 ( like new)
- Price
- H/p no : 019- 388 5148( Ken )
limcsmis- Regular
- Number of posts : 64
Registration date : 2009-02-18
» Cypress Serious Cinema Home Theater System
» Jamo S 626 HCS3 Home Cinema System (Used)
» WTS: Epson Home Cinema TW8300w WirelessHD 3LCD Home Theater Projector
» KEF KIT 100 Home Theater System
» JBL SCS 140 5.1 Home Cinema System (used)
