Yamaha 11-Channel MX-A5000 Power Amplifier OFFER!
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Empty Yamaha 11-Channel MX-A5000 Power Amplifier OFFER!
Post by actsessory on Sun Apr 10, 2016 10:40 pm
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Yama-logo
Yamaha Aventage MX-A5000 11-Channel Power Amplifier
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Mxa5000_poster
“A genuine bargain for such great sound + 11-channels”
Absolute Quality. Massive Power.
Reference standard build quality. Top-Grade AVENTAGE Series performance.
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Mx-show
A no-compromise design policy for this amplifier
The muscular, matching MX-A5000 amplifier is a discrete structured 11 channel power amplifier perfectly matched to the CX-A5100 AV processor.
It utilises its discrete amps to deliver astonishing levels of power.
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Yamaha-1
It boasts 150W (at 8ohm, full range, 2-ch driven) power output for all 11 channels with a phenomenally low THD of just 0.06%.
Yamaha’s CX-A5100/MX-A5000 pairing makes a superb choice for a high-end home theatre.
Overwhelming Power and High Density Presence Achieved by 11.2 Channel Separate AV Amps
The key to MX-A5000 sonic signature is its current feedback, which reacts in real-time, allocates additional power resources from channels and not using their full allocation of power.
It intelligently allocates this unused power to channels demanding more especially in ‘power-hungry’ scenes and sound tracks.
The current feedback uses three stage Darlington circuit that has superior phase properties and is resistant to speaker impedance fluctuation.
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Mx5000-show
Very useful when you have lower-sensitivity speakers or when you’re watching movies with a high dynamic range soundtrack.
The amplifier seemingly cruises through these passages without fuss.
The 11 channel power amp is configurable to use as 11 full range channels, or 5 bi-amped channels, or a bi-amped 2nd zone and another pair of speakers in a 3rd zone.
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Zoning-a5000-amp
Benefits from the AVENTAGE ethos by using only the best components, highest quality parts, like a high-output toroidal power transformer and two 27,000μF block capacitors to ensure abundant power delivery and optimum performance.
All parts are strictly selected based on listening tests.
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Mx5k2
Greater Sound Purity with Specially Designed High Rigidity Advanced Chassis that eliminates vibrations.
H-frame to strengthen the chassis, bootsting mechanical strength, with a fifth foot to keep everything stable.
Yamaha’s signature A.R.T. (Anti-Resonance Technology) Wedge in the center of the bottom cover acts as an additional vibration countermeasure and firmly supports the internal circuits.
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! H-shapre
The large toroidal transformer and the high capacity (27000uf) block capacitors are positioned close to the centre.
The fifth foot, clearly visible below, helps to stabilise the huge transformer which is positioned right above it.
Independent top cover and side panels
The brushed aluminium side panels look absolutely gorgeous.
Plus a double bottom, of vibration control plates made of 1/8 inch (1.6 mm) black steel, the same type of construction used on the previous flagship model Z11.
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Yamaha-base-mx-a5000
Symmetrical Power Amplifier Layout – precisely planned, left and right channels are physically and electrically isolated.
This naturally maximizes channel separation, also greatly improves signal to noise ratio to achieve a wide, open sound stage.
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Mx-a5000-c
  • 150 W per channel (8 ohms, 20 Hz-20 kHz, 0.06% THD, 2 ch driven)
  • 170 W per channel (8 ohms, 1 kHz, 0.9% THD, 2 ch driven)
  • Custom made, large-size toroidal transformer
  • Current feedback power amp with three stage Darlington circuit
  • 27,000μF custom block capacitors
  • Specially designed high rigidity chassis and highest quality parts
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Yamaha-side-panel-mx-a5000
  • Noise resistant XLR balanced connections
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Mx5000-b
  • Bi-amping capability with channel selector
  • High quality gold-plated speaker terminals
  • Auto Power Standby
  • Handy trigger control (trigger in / out and through out )
  • Detachable high quality thick AC power cord
  • Power Consumption 650W
  • Weights at 25.4 kg
  • Dimension: 17-1/8″W x 8-1/4″H x 19-3/16″D
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Aven9
High output, high efficiency, large size toroidal transformer, two specially developed high capacity (27,000μF) block capacitors, ensures sound capable of superior musical expression.
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Mxa5000_interior
“One brute of a power supply; check out those caps”
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Mx-black
Speaker output terminals are high quality gold-plated types
Noise Resistant, Highly Reliable Balanced Connection
In Addition to 11.2 Channel Output, 5 Channel Bi-amping and Other Configurations Are Possible
Extra amps can be used to power multiple zones in addition to the main room, letting you configure your system for music play in a bedroom or kitchen.
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Mx5k1
“The MX-A5000 has generous connection space”
Speaker Impedance Selection
The impedance selector on the rear panel of the MX-A5000 matches amplifier output current to various speaker impedances.
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Lgoos
EISA AWARD 2014-2015
Great product!!!!
 Distributes the sound evenly and marvelously. I’ve never enjoyed movies like that before.
 I have been used Yamaha back in 1988,CX-1000 & MX-1000 for all those years and its still kicking they put out excellent power, clean & purest sound, So I just bought a new Yamaha CX-A5000 & MX-A5000 these systems are awsome the sound is just blow my mind versus my old system they both excellent,but the new one is punchier
This is probably the last amp I ever own
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Ll
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Mx5000-a
“This amp can deliver and hold current for deep bass and intense dynamic bursts of main channel audio and surround effects, as well as high-res multichannel music playback from Blu-rays or music-download sources, such as 2L.”
“The Yamaha kicks butt with the Bruce Willis Live Free and Die Hard soundtrack.
Clean, dynamic and open! That is what you want from AV amplification.”
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Aven8
“Strain is not a word you can associate with the Yamaha. The BD soundtrack’s sonic signature, like the AudioControl receiver’s, was big and imposing with a great width and space spread among the tracks’ varying elements. Right off the bat, I could tell that the MX-A5000 has the capability to relay the massive dynamics of the linear PCM soundtrack.”
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Setup
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Setup-mx
"All in all, the Yamaha MX-A5000 excels not only at playing your movie soundtracks, but also is a pretty darn good music amp
If you want it all in one amp, this is one to consider.
I did not have any complaints with the Yamaha MX-A5000.
Easy to setup, plenty of space for the speaker cables to co-exist with the input cables, and it has a 12V trigger for remote turn on.
In the context of high-end multichannel amps, I rank the Yamaha up near the top — especially with its price tag at under $3,000"
by John Gatski - Reviewer for • Audiophile • Home Theater • Personal Audio • Home Recording
* Retails RM10900, RM8490
* Credit Card is accepted
Contact 012 6116917
Subang Jaya SS 14
actsessory
Number of posts : 1706
http://www.actsessory.com
Yamaha 11-Channel MX-A5000 Power Amplifier OFFER! Empty Re: Yamaha 11-Channel MX-A5000 Power Amplifier OFFER!
Post by actsessory on Sat Apr 30, 2016 11:17 pm
Ready stock, ready deal.
actsessory
Post by actsessory on Tue May 31, 2016 11:49 pm
Welcome for inquiries.
actsessory
Post by actsessory on Mon Aug 29, 2016 6:42 pm
actsessory
Post by actsessory on Wed Sep 21, 2016 10:47 am
actsessory
Post by actsessory on Sat Feb 25, 2017 12:40 pm
Demo available soon...
actsessory
Post by hwteh on Sat Mar 18, 2017 5:43 pm
actsessory wrote:Ready stock, ready deal.
Chong, how much for both cx and mx?
hwteh
Number of posts : 3
Registration date : 2016-02-18
Post by actsessory on Wed Jun 28, 2017 3:19 pm
Ready stock.
actsessory
Post by actsessory on Sat Jul 22, 2017 5:27 pm
Pre and post system bump
actsessory
Post by actsessory on Tue Aug 15, 2017 9:46 pm
Stock in hand.
actsessory
Post by actsessory on Sun Oct 22, 2017 8:16 pm
actsessory
Post by actsessory on Tue Nov 14, 2017 7:12 pm
ready stock
actsessory
Post by actsessory on Thu Dec 07, 2017 7:57 pm
actsessory
Post by actsessory on Thu Sep 27, 2018 10:40 am
The
actsessory
Post by actsessory on Fri Nov 02, 2018 4:44 pm
OFFER
actsessory
Post by actsessory on Sat Nov 24, 2018 12:11 pm
actsessory
Post by actsessory on Sat Dec 22, 2018 10:53 am
Limited unit left
actsessory
Post by actsessory on Sat Jan 26, 2019 5:31 pm
actsessory
Post by actsessory on Wed Mar 06, 2019 7:12 pm
Ready stock
actsessory
Post by actsessory on Fri Apr 19, 2019 7:03 pm
Available
actsessory
Post by actsessory on Mon May 13, 2019 4:37 pm
Ready stock
actsessory
Post by actsessory on Sun Jun 09, 2019 11:15 pm
actsessory
Post by actsessory on Fri Mar 13, 2020 6:35 pm
Available
actsessory
Post by actsessory on Sat Mar 14, 2020 7:54 pm
EVEN LOWER PRICE!  now
actsessory
Post by actsessory on Wed Mar 25, 2020 10:30 pm
Ready stock
actsessory
