Audio Research VSi60 vacuum tube integrated amplifier
Audio Research VSi60 vacuum tube integrated amplifier brand new, made in USA, powerful 50 watts per channels, now selling at rm17999.
Please call / whatsapp Alfred 017-3116863
Description:
The VSi60 clearly proves that you do not have to spend a fortune to enjoy truly great sound at home. Built by hand in Plymouth, Minnesota, to the same exacting standards as our renowned Reference series, the VSi60 offers remarkable sound quality and value. Its rated output of 50 watts per channel does not convey the VSi60's ability to drive power-hungry, low-impedance loudspeakers. We designed the VSi60 with the finest full-range speakers, not compact monitors. Dynamics are lifelike with a sense of ease normally associated with larger amplifiers. Yes, its resolving power is surprising, allowing you to hear details that were previously hidden in your recordings, but that resolution is in service of the music — grainless, tonally accurate and refined.
Specification:
POWER OUTPUT
50 watts per channel continuous from 20Hz to 20kHz. 1kHz total harmonic distortion typically 1.5% at 50 watts, .05% at 1 watt.
FREQUENCY RESPONSE
(-3dB points at 1 watt) 1.0Hz to 80 kHz.
INPUT SENSITIVITY
0.47V RMS Single-ended for rated output. (32.5dB gain into 8 ohms.)
INPUT IMPEDANCE
50K ohms Single-ended.
INPUTS
(5) CD, Tuner, Video, SE1, SE2 (Single Ended RCA connectors).
MAXIMUM INPUT
3.5V RMS (any input).
OUTPUT POLARITY
Non-Inverting (any input).
PUSH BUTTONS
Volume up, volume down. (103 steps, 20 LED indicators), Input, Mono, Mute, Power. All functions on IR remote control.
OUTPUT TAPS
8 ohms, 4 ohms.
MONO SUBWOOFER OUTPUT
1V RMS at rated power.
OVERALL NEGATIVE FEEDBACK
7dB.
HUM AND NOISE
Less thatn 0.1mV RMS — 106dB beow rated output (IHF weighted, Vol down).
POWER SUPPLIES
Electronically regulated Low and High voltage supplies for input stages. Automatic 30 sec. warm-up/brown-out mute.
POWER SUPPLY ENERGY STORAGE
Approximately 166 joules.
POWER REQUIREMENTS
100-125VAC 60 Hz (200-250VAC 50Hz) 300 watts at rated output, 500 watts maximum, 200 watts at "idle".
TUBES REQUIRED
2 - Matched pair KT120. Power Output 2-6H30 driver.
DIMENSIONS
14" (35.6 cm) W x 8" (20.3 cm) H x 16"(40.6 cm) D. Rear connectors extend .88" beyond chassis.
WEIGH
34.8 lbs. (15.8 kg) Net; 38.3 lbs. (17.4 kg) Shipping.
Description:
Specification:
POWER OUTPUT
FREQUENCY RESPONSE
INPUT SENSITIVITY
INPUT IMPEDANCE
INPUTS
MAXIMUM INPUT
OUTPUT POLARITY
PUSH BUTTONS
OUTPUT TAPS
8 ohms, 4 ohms.
7dB.
HUM AND NOISE
POWER SUPPLIES
POWER REQUIREMENTS
TUBES REQUIRED
DIMENSIONS
WEIGH
Last edited by alfredce6333 on Mon Aug 15, 2016 2:11 pm; edited 3 times in total (Reason for editing : all cap)
alfredce6333- Dealer\Reseller\Trader\Service Provider
- Number of posts : 296
Registration date : 2016-04-08
» Audio Research VSi60 Vacuum Tube Integrated Amplifier
» Sold - Audio Research VSi60 tube integrated amplifier (Used)
» Audio Research VSi60 Integrated Amplifier (Used)
» Audio Research VSi60 Integrated Amplifier (sold)
