QED Silver anniversary XT Bi-Wire Speaker Cable (new)
http://www.sonicsoundaudio.com/product_info.php?products_id=69
SGD$36/- per metre
Free Shipping to Malaysia
QED Silver Anniversary XT, runaway winner of the 2005 WHAT HIFI? Award for 'Best Speaker Cable' and Cabling 'Product of the year'. The new cable successfully introduces QED's high end 'X–Tube' technology into a mid-priced product for the first time. The precise cylindrical construction of the silver-plated, 99.999% pure, oxygen free copper cables reduces the distortion caused by 'skin effect'. The result is a completely neutral speaker cable that allows good hi-fi and home cinema equipment to shine.
The cable is a standard 'figure 8' configuration and is attractively finished, with each silver-plated core visible through a flexible 3.9mm diameter clear polyethylene outer sheath. For ease of assembly and to ensure correct speaker 'phasing' the inner spacers, which maintain the cylindrical configuration, are each coloured coded red or white and are 'crushable' to allow straightforward crimping with 'Airloc' speaker plugs.
Reviews:
"Take an Award-winning speaker cable. Double up on the connectors to make it biwire, and the result is this version of QED's Silver Anniversary XT. Does it sound good? You bet.", "This is a great cable and a clear class-leader. Well done QED...again!"
"What a great speaker cable this is. This is the XT's second Product of the Year Award, and it's richly deserved. No rivals can match the QED for resolution and transparency, and it's priced sensibly, too, as well as being balanced enough to suit a wide range of systems". Well done, QED!"
Features:
3 layers of 99.999% SPOFC measuring 16 x 5 x 0.1mm
Polyethylene outer jacket and Teflon air core
Unique SPOFC triple braid 5 x 16 x 0.1mm
Compressible Teflon Aircore for ease of termination
Low resistance, low capacitance and low inductance
Easy strip Polyethylene outer jacket
4 x 1.88mm2 conductor cross sectional area
Price is per un-terminated metre.
SGD$36/- per metre
Reviews:
Features:
» QED Silver Anniversary Bi-Wire Speaker Cable - 3m piece (New)
» QED Silver Anniversary Bi-wire speaker cable (SOLD)
» QED Silver Anniversary Bi-Wire Speaker Cable (Used)SOLD
» QED Silver Anniversary XT bi-wire speaker cable (SOLD)
» QED Silver Anniversary Bi-wire 2 to 4 Speaker Cables 2m pair (Used)
