Marantz CD6006 CD Player With USB
Marantz CD6006 CD Player With USB Brand New, Now Selling at RM2,499. Free Shipping Within West Malaysia.
The new CD6006 is a fine-tuned version with even more specially selected components and new layout circuit compared to its CD6005 predecessor. We also added more rigid feet to further eliminate vibration. The oversized power supply feeds the digital and analog circuitry of the player, where the high-quality CS4398 DAC converts digital signals to analog, this is then 'pushed' to the gold-plated synch outputs by Marantz's own small signal amplifier, the HDAM-SA2. In addition, we have included a new remote that also controls the PM6006 amp.
The CD6006 is a match made in heaven for the music lover who wants nothing but the best performance at an attractive price, and it is also perfect for lovers of portable music, thanks to its iPod-digital connectivity. The CD6006 also features a newly developed, complex headphone amplifier with Headphone amp gain setting for a wider range of headphones.
新款CD6006使用精選的元件與新的電路,是CD6005的後續機種。 CD6006增加更剛性的腳墊以進一步消除振動。超大的電源為
本機的數位與類比電路供電,使用高品質CS4398 DAC將數位訊號轉換為類比訊號電路後由馬蘭士專利的HDAM-SA2 放大模組“推送” 訊號至鍍金同步輸出訊號端。此外,本機隨附的新型遙控器可控制同品牌PM6006擴大機。CD6006配備iPod 數位連接,方便播放聆聽攜帶式音樂 。新開發的高級耳機擴大機三段增益設定可搭配多樣耳機。性能優異,價格迷人,CD6006是音樂愛好者的最佳匹配。
Marantz HDAM Technology
HDAM 高速模組 (Marantz HDAM Technology)
Marantz developed its own discrete circuit boards to replace standard IC's. These HDAM's consists of discrete surface mount components with short mirror image L/R signal paths. Those devices are doing exactly the same thing as the Op-Amps, but outperform the regular IC Op-amps dramatically in terms of the Slew Rate and reduced noise level, resulting in a much more dynamic, accurate and detailed sound. Over the years Marantz developed different types of the HDAM to improve quality and to fit to the special requirements of a product category like CD or amplifier.
Marantz開發了自己的獨立電路板來替代標準IC。 這些HDAM由具有最短L / R信號路徑的獨立式安裝組件組成。 這些器件與Op-Amps完全相同,但在擺率和噪聲水平方面優於常規IC運算放大器,從而產生更加動態,準確和詳細的聲音。 多年來,Marantz開發了不同類型的HDAM,以提高質量,並滿足諸如CD或功放等產品類別的特殊要求。
High Current Power Supply
大電流電源 (High Current Power Supply)
The audio power supply employs high speed, high current Shottky Barrier Diodes and high current storage capacitors.
CD6006電源具有高電流高速肖特基二極體和高電流存儲電容器。
Reference Quality D/A Conversion
參考級數位 D/A 轉換晶片
The CD6006 features high resolution D/A conversion and is equipped with the reference class CS4398 D/A converter, which provides up to 192 kHz/24 bit resolution for optimum fidelity with high resolution audio file types.
CD6006具有高解析D / A數位轉換,並配有參考級CS4398 D / A轉換晶片組,提供高達192 kHz / 24位元,以獲得高解析音頻檔案類型的最佳解析。
High Slew Rate Op-amp + HDAM-SA2 Headphone Amplifier with Headphone Amp Gain Setting (Low/Mid/High)
高轉換率運算IC晶片組+ HDAM-SA2耳機擴大線路,具備耳機擴大增益設定(低/中/高)
The headphone amplifier section features our HDAM-SA2 circuit with three gain settings (Low/Mid/High) for a wider range of headphones.
耳機擴大部分採用我們的HDAM-SA2電路,具有三種增益設定(低/中/高),適用於更多樣的耳機匹配。
Plays USB Audio Sources (MP3/WMA/AAC/WAV)
播放USB音頻訊源 (MP3/WMA/AAC/WAV)
The CD6006 can play back MP3, WMA, WAV and AAC files from a connected USB storage device. It is also specifically "Made for iPod/iPhone", to directly play back your iDevice music through the CD Player's high quality D/A converters.
CD6006可以連接USB儲存設備播放MP3,WMA,WAV和AAC檔案。 它也特別是“專為iPod / iPhone”,經由CD播放機的高品質D / A轉換晶片直接播放您的iDevice音樂。
Chris 012-2309169
amplifier
speaker
cd player
SPECIFICATIONS
plays CDs, CD-Rs & CD-RWs plus MP3, WMA, and AAC CDs
參考級數位 D/A 轉換晶片
Chris 012-2309169
amplifier
speaker
cd player
SPECIFICATIONS
- front-panel USB input (type A) for USB flash drive, iPod, iPad, or iPhone
- USB input supports WAV, MP3, AAC, and WMA file playback
- high-performance 192kHz/24-bit Cirrus Logic CS4398 digital-to-analog converter
- double-layered metal bottom plate for vibration resistance
- centralized disc mechanism resists vibration for improved sound quality
- Marantz HDAM (Hyper Dynamic Amplifier Module)-SA2 used in analog circuitry for faster signal transfer and better transient response
- robust, high-speed power supply for rich, dynamic sound
- remote
- optical and coaxial digital outputs
- gold-plated stereo analog outputs
- built-in headphone amplifier with full-size headphone jack and volume control
- remote control input/output (for use with Marantz receivers and amps with a compatible remote control in/out jack)
- detachable power cable
- frequency response: 2Hz - 20kHz
- dynamic range: 100 dB
- signal-to-noise ratio: 110 dB
- total harmonic distortion: 0.002%
- 17-3/8"W x 4-1/8"H x 15-1/8"D
- Number of posts : 1491
» Marantz-CD6006-Cd Player-(NEW)
» Marantz CD6006 CD Player (NEW)
» Marantz CD6006 Cd Player (sold)
» Marantz CD6006 (no longer available)
