MS HD Power MS E02 Rhodium 6 Way Filtered Main Block (Sold)
MS HD Power MS E02 Rhodium 6 Way Filtered Main Block (Sold) Empty MS HD Power MS E02 Rhodium 6 Way Filtered Main Block (Sold)
Post by useditem123 on Mon Apr 01, 2019 9:06 am
Product Description
This MS E02 Rh is the Rhodium version of MS HD Power's 6 way UK filtered mains block with surge protection, designed with the audiophile and enthusiast in mind. Featuring selected premium quality filtering components from Germany, MS HD Power have spared no expense with making the MS E02 Rh a high performance mains block, delivering quality power to all your equipment.
The MS-E02s is built to extremely high standards, with the highest quality materials and components throughout. So sure of its quality are MS HD Power, that it comes with a lifetime warranty. The block utilises a heavy gauge metallic chassis with vibration absorption spikes, ensuring isolation and RF/EMI rejection.
Key Features
- 100% Comply with BS-1363 and BS-5733 Safety Standards
- Multi-Stage A/C Line Filter with PRRT Noise Suppressor Embedded
- Selected Premium Quality Filtering Components From Germany
- 6 Premium Grade Sockets High Spring Rate Phosphor Bronze Sockets Clips Pass the BS Standard 30,000 times plug IN / OUT test
- 1.0 µm Rhodium Quadri-Plated Coating to All Power Clips
- 5 mm² Power Transmission Bus Bars with 1.0 µm Pure Silver Plating Enhances High Current Flow
- 4mm² Silver Plated 6N OFC Internal Wires with Silver-Rich Soldering
- 1.0 µm Rhodium Plated IEC Inlet Adapts User-Selected Power Cords
- Heavy Gauge Metallic Chassis with Vibration Absorption Spikes
- 20A Resettable Safety Switch Protect Equipment Connected
Tech Specs
Number of outlets: 6
Type of outlets available: UK Unswitched
Standard mains inlet: IEC C-14
Mains Voltage: 200 - 240 VAC / 50~60Hz
Max. Current: 13 Amp.
Max. Wattage: 3,000 Watt (230V)
Max. Surge Suppression: 2,100Joule / 72,000A for MS-E02S Rhodium only
Dimensions: 110mm x 410mm x 92mm (W x L x H)
Net Weight: 2.6 KG (net)
CONDITION : 8/10 (No original box)
AGED : 4 YEARS +
PRICE : sold
Interested Kindly WhatsApp message  only to +6016 4554 333
Last edited by useditem123 on Wed Sep 25, 2019 12:08 pm; edited 1 time in total (Reason for editing : sold)
useditem123
Number of posts : 1334
MS HD Power MS E02 Rhodium 6 Way Filtered Main Block (Sold) Empty Re: MS HD Power MS E02 Rhodium 6 Way Filtered Main Block (Sold)
Post by useditem123 on Tue May 14, 2019 1:19 pm
useditem123
