Paradigm DSP-3200 Subwoofer SOLD
2 posters
Paradigm DSP-3200 Subwoofer SOLD Empty Paradigm DSP-3200 Subwoofer SOLD
Post by choyaudiovisual Sat Apr 06, 2019 2:58 pm
Paradigm DSP-3200 Subwoofer SOLD Pardsp10
Paradigm DSP-3200 Subwoofer SOLD Dsp-3210
DSP-3200
12-inch single driver, bass-reflex, dual high-velocity low-turbulence resistive ports, built-in amplifier, USB Port / PBK Interface. 900 watts Dynamic Peak / 300 watts RMS.
Product details of PARADIGM DSP-3200 12" 900 WATTS POWERED SUBWOOFER
Big Bass for a Small Space
High-power DSP Series subwoofers are the result of Paradigm’s multi-year R&D effort to achieve exceptional high performance while accommodating the growing desire for installation flexibility. Not everyone wants a high-performance subwoofer on full display, so models are front-firing and front-ported with removable grilles, making them ideal for “hidden” installations. For those who want it all … exceptional high performance (including the sonic benefits of digital signal processing!), a smaller footprint, flexible placement options and killer price points, DSP subwoofers fit the bill.
Control Facilities:
• Auto On/Off
• Subwoofer Level
• Subwoofer Cut-Off Frequency (continuously variable 35 Hz – 150 Hz);
Bypass Option
• Sub/Sat Phase Alignment (0° to 180°)
• USB Port/PBK Interface
Input Facilities:
• Line-level Inputs
Advanced High-Power Class-D:tm: Amplifiers deliver massive amounts of high-current power with minimal distortion. 900 watts Dynamic Peak / 300 watts RMS.
Forward-Firing Drivers with Advanced CAP:tm: Carbon / Aramid-Fiber Polypropylene Cones. Advanced cone material combines exceptional stiffness/low mass with excellent internal damping for tremendous freedom from unwanted resonances.
Advanced Suspension Design and Large Magnet Structures encourage extended cone excursion while maintaining superb control over cone movement.
High-Efficiency Dual-Ported Design. High-velocity low-noise ports with critically flared openings serve to reduce turbulence distortion. Front-ported design accommodates installation flexibility.
Removable Grilles with AVS:tm: Airflow Ventilation System allow release of the enormous air pressure generated by these high-output designs.
Acoustically Inert MDF Enclosures serve to limit unwanted panel resonances and vibrations, ensuring clean, clear and very articulate bass performance.
DSP-3200 Specifications
Design                                       Single driver, bass-reflex, dual high-velocity low-                                                     turbulence resistive ports, built-in amplifier, USB                                                     Port / PBK Interface
Amplifier                                    900 watts Dynamic Peak / 300 watts RMS
Amplifier Features                       Auto-On / Off, soft clipping
Room Correction                          pbk-1
Low Pass Filter Frequency             Variable 35 Hz - 150 Hz; Bypass Option
Frequency Driver                         305-mm (12 in) CAP:tm: cone, ceramic / ferrite                                                          magnet, 50-mm (2 in) 4-layer voice-coil, AVS:tm:                                                      die-cast heatsink chassis
Low Frequency Extension             22 Hz (DIN)
Sub / Sat Phase Alignment           0° - 180°
Finishes                                      Black Ash
Inputs                                        RCA (L/R-Mono) for L/R Line-Out or Sub-Out /                                                       LFE-Out of receiver, processor or other line-level                                                     source
Weight                                       54 lbs. (24.5 kg)
Dimensions   HxWxD                   18.25" × 14" × 19.5"
Includes grilles and feet              (46.4cm × 35.6cm × 49.5cm)
Conditions: 10/10 (New Ready Stock)
Price: FINISH exclusive postage
Whatsapp: Choy 012-5685484
Last edited by choyaudiovisual on Tue May 11, 2021 12:31 pm; edited 1 time in total
Number of posts : 3497
Paradigm DSP-3200 Subwoofer SOLD Empty Re: Paradigm DSP-3200 Subwoofer SOLD
Post by choyaudiovisual Fri Mar 06, 2020 9:41 am
Post by choyaudiovisual Sat Mar 28, 2020 1:39 pm
Post by choyaudiovisual Sat Apr 18, 2020 3:27 pm
UP
Post by choyaudiovisual Tue May 12, 2020 11:18 am
Post by choyaudiovisual Wed May 27, 2020 10:46 am
Post by choyaudiovisual Mon Jun 15, 2020 12:45 pm
Post by choyaudiovisual Sat Jul 04, 2020 9:22 am
Post by ikah Thu Jul 09, 2020 6:41 pm
can sell at RM 3050..
cod at ipoh weekend
ikah
Number of posts : 16
Registration date : 2010-05-27
Post by choyaudiovisual Fri Jul 24, 2020 10:26 am
Post by choyaudiovisual Thu Aug 06, 2020 9:58 am
Post by choyaudiovisual Mon Aug 24, 2020 9:15 am
Post by choyaudiovisual Wed Sep 30, 2020 9:10 am
Post by choyaudiovisual Tue Mar 30, 2021 8:58 am
Post by choyaudiovisual Tue May 04, 2021 10:26 am
