Condition: Item is brand new. Openned the box for checking and testing only.
Selling this unit for sold
EMI-Absorbing Formula GC-303
•DVD and DVR (Filter 1)
•CD、Cable and SAT(Filter 2)
•TV and Projector (Filter 3)
•Zone 1, 2, 3 • Green
•Breaker indicator • Red
•Digital voltage meter • Red
•Digital amperage meter • Red
•Rear panel
•Input x 1 • Output x 2
•3 Remote control triggers
•Sequence switch
Under the Hood
On the Track
SPECIFICATIONS
15 A Max. 230V AC
https://www.lelong.com.my/furutech-daytona-303-multi-mode-power-filter-stylelaser-211217194-2020-01-Sale-P.htm
http://av2day.com/2015/05/furutech-daytona-303-plc/
https://www.analogueseduction.net/mains-blocks/furutech-daytona-303-6-way-schuko-power-filter.html
•Rear panel
•Sequence switch
FEATURES
The Daytona: 24 Hour Protection for Pro A/V and High Performance EnthusiastsAll enthusiasts are looking for the same qualities: Verisimilitude to the original event, a sense of engagement promoting suspension of disbelief, an immersion in audio and video experience. To engage without effort requires meticulous preparation of the entire playback chain especially including the AC mains supply.
Under the Hood
On the Track
SPECIFICATIONS
15 A Max. 230V AC
» Furutech Daytona 303 Multi-Mode AC Filter/Power Distributor
