Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set)
Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set) Empty Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set)
Post by Avp.online Tue Aug 20, 2019 4:22 pm
Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set) 18280811
Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set) 419xfx15
Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set) C11
Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set) Front11
Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set) R11
Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set) Sub60014
Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set) 12314
Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set) 7fabaac7a2600fa50bcb031016a7d665
Product details of Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set)
  • Taga Harmony TAV-406 Speaker Set
  • Taga TAV-406F v.2 - Floorstanding Speakers
  • Taga TAV-406C v.2 - Center Speaker
  • Taga TAV-406S v.2 - Surround Speakers
  • Taga TSW-90 v.3 Active Subwoofer
Design: 3-way, crossover points 500Hz 3.8kHz
High-Frequency Driver:25mm (1"), TWG faceplate
Bass / Midrange Driver:133mm (5.25")
Bass Driver:2 x 133mm (5.25")
Recommended Amplifier Power:20-120W
Frequency Response:44Hz-25KHz
Impedance:6 ohm
Sensitivity:89 dB
Dimensions (H x W x D):88 x 20 x 23 cm (excl. spikes)
Weight (net):20 kg pair
Design: 2-way, crossover point 4.5kHz
Bass / Midrange Driver:2 x 102mm (4")
Recommended Amplifier Power:20-100W
Frequency Response:58Hz-25KHz
Impedance:6 ohm
Sensitivity:88 dB
Dimensions (H x W x D):15 x 38 x 16 cm
Weight (net):3.4 kg pc
Bass / Midrange Driver:102mm (4")
Impedance:6 ohm
Sensitivity:86 dB
Dimensions (H x W x D):25 x 15 x 16 cm
Weight (net):4.6 kg pair
TSW series subwoofers are single driver, bassreflex construction with high-current built-in amplifiers. TSW   subs can deliver the most powerful, deep bass with staggering definition, location and dynamics never met at this price level before. Our subwoofers are the absolute best buy in subwoofers!
High-power and high-current amplifiers deliver astonishingly deep, thundering bass with very low distortion and perfect definition.Our advanced subwoofer drivers ensure superior flat power response and ultra-low distortion at any volume levels.
TSW subwoofers are ideal complement to your sound system and their high power and staggering dynamics bass can be only compared with far more expensive subwoofers from other competitors.
The v.3 version utilizes a much stronger and a little lighter woofer cone - it can move quicker and more frequently generating higher bass pressure and better dynamics.
Control:
  • Auto On-Off function with the "ON-AUTO" manual mode switch (v.3 only)
  • Subwoofer Level
  • Subwoofer Cut-Off Frequency (35Hz - 150Hz variable)
  • Phase Switch (0° / 180°)
Inputs / Outputs:
  • Line-level Input
  • Sub Input
  • High-level Input
Specification
Design: Bassreflex, TLIE Enclosure
Bass Driver:255mm (10”) Matt Paper Cone
Frequency Response:30Hz-150Hz
Amplifier Power:90W RMS / 250W Dynamic Peak
Dimensions (H x W x D):40 x 33 x 40.5 cm (incl. feet)
Weight (net):15 kg pc
**NEW STOCK**
Arrow PRICE : RM 3750
Arrow POSTAGE : RM 30.00
PLS WHATSAPP OR CALL 0189595906, LEE
Avp.online
Club Member
Club Member
Number of posts : 32
Registration date : 2018-09-15
Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set) Empty Re: Taga Harmony TAV-406 v.2 Set + Taga TSW-90 v.3 Active Subwoofer (5.1 Set)
Post by Avp.online Fri Aug 30, 2019 3:15 pm
Avp.online
Club Member
Club Member
