Klipsch KG 2.2V USA Made Big Size 2-way 100W horn tweeter center speaker
Klipsch KG 2.2V USA Made Big Size 2-way 100W horn tweeter center speaker Empty Klipsch KG 2.2V USA Made Big Size 2-way 100W horn tweeter center speaker
Post by HiFiLab on Tue Feb 11, 2020 4:29 pm
Klipsch KG 2.2V USA Made Big Size 2-way 100W horn tweeter center speaker 20200168
Klipsch KG 2.2V USA Made Big Size 2-way 100W horn tweeter center speaker 20200167
Klipsch KG 2.2V USA Made Big Size 2-way 100W horn tweeter center speaker 20200169
Klipsch KG 2.2V USA Made Big Size 2-way 100W horn tweeter center speaker 20200172
Klipsch KG 2.2V USA Made Big Size 2-way 100W horn tweeter center speaker 20200170
Klipsch KG 2.2V USA Made Big Size 2-way 100W horn tweeter center speaker 20200171
Made In USA
Price : RM 780
In good working condition
black center channel by Klipsch in really good condition.
All drivers are in excellent condition. FREQUENCY RESPONSE: 50Hz-20kHz(+-)3dB SENSITIVITY: 93dB @ 1watt/1meter POWER HANDLING: 75 watts maximum continuous (375 watts peak)
NOMINAL IMPEDANCE: 8 ohms
TWEETER: K-86-K 1" (2.54cm) Phenolic dome compression driver HIGH FREQUENCY HORN: Exponential Cone
WOOFER: Two K-1008-KV 6.5" (16.51cm) Injected Carbon Graphite cones
ENCLOSURE MATERIAL: Medium density fiberboard construction (MDF) ENCLOSURE TYPE: Bass reflex via rear-mounted port DIMENSIONS: 19.5" (49.5cm) x 9.25" (23.5cm) x 9.25" (23.5cm)
WEIGHT: 23.5 lbs. (10.7kg)
Finished Black
HiFiLab
Number of posts : 2667
Klipsch KG 2.2V USA Made Big Size 2-way 100W horn tweeter center speaker Empty Bump
Post by HiFiLab on Fri Mar 06, 2020 6:58 pm
Up
HiFiLab
