Wharfedale Opus2 M2(Withdraw)
Wharfedale Opus2 M2 3 way bookshelf speaker with wharfedale JADE stand
Condition: 9/10
Drive Unit Technology: Opus uses advanced neodymium and alnico magnets to produce intense and focused flux fields that provide a tight grip on drive unit movement. The soft dome midrange, the most advanced unit of its kind, provides tonal balancing throughout the range. The bass cone, a woven carbon fibre composite unit exhibits incredible linearity and control with a textbook response and rise time. Dynamics are dramatically harder and faster with no noticeable bass overhang.
Opus ‘Tri-pole’ Surround: Twin pairs of dome mid-ranges and tweeters fire at angles. This speaker is designed to be hung on rear or side walls in pairs to create the ideal rear soundstage for modern multi-channel systems. The front firing 6.5” or 170mm bass driver extends the bass response to around 60Hz.
Gold-plated Terminal & Spikes: Heavy duty, shielded and gold-plated tri-wire terminals are supplied. Bridge links for either single, bi or tri wiring, (or amping) enable a wide choice of amplifier and cable options to suit every budget and taste. The floorstanding models are supplied with integral plinth stand, securely making a very good mechanical contact even on uneven floors or carpet pile.
Condition: 9/10
Type 3-way stand-mount | ||||
Bass driver | 200mm KEVLAR | |||
Mid-Range | 75mm Textile dome | |||
Tweeter | 25mm Textile dome | |||
Nominal Impedance | 6ohm (8ohm compatible) | |||
Frequency Response +/- 3dB | 40Hz - 43kHz | |||
Recommended Amplifier Power | 50 - 200w | |||
SPL (1w@1m) | 88dB | |||
Dimensions (h x w x d)mm | 505 x 255 x 450 | |||
Nett weight | 16.4kg |
tongho- Frequent Contributor
- Number of posts : 879
Amplification: Accuphase E470
Speakers: Quad z3
Speakers: Quad z3
Speakers: Quad z3
Speakers: Quad z3
Speakers: Quad z3
