M2tech Yound DSD DAC
M2tech Yound DSD DAC Empty M2tech Yound DSD DAC
Post by Sonerin on Fri Mar 13, 2020 5:30 pm
M2tech Yound DSD DAC 89072910
M2tech Yound DSD DAC 89293710
M2tech Yound DSD DAC 89514410
DAC comes with remote.
D/A Converter IC:
Texas Instruments PCM1795
PCM Sampling Rates - Asynchronous USB:
44.1, 48, 88.2, 96, 176.4*, 192*, 352.8**, 384**kHz
DSD Sampling Rates - Windows Asynchronous USB ASIO:
2.8224 MHz (DSD64)
5.644,8 MHz (DSD128)
PCM Sampling Rates - Coaxial SP/DIF:
44.1, 48, 88.2, 96, 176.4*, 192* kHz
PCM Sampling Rates - Optical (TOSLINK):
44.1, 48, 88.2, 96kHz
Total Harmonic Distortion
0.0008% (-3dBFS, balanced, 1kHz)
0.003% (-3dBFS, single-ended, 1kHz)
Signal-to-Noise Ratio
118dB (0dBFS, balanced, “A”-weighted)
114dB (0dBFS, single-ended, “A”-weighted)
A-weighted, 2 Vrms:
Digital Inputs:
USB 2.0, SP/DIF Coaxial RCA and BNC, SP/DIF TOSLINK (optical)
Digital Volume Control Steps:
0.5 dB
Line Output Level Unbalanced:
5.4Vrms @0dBFS (balanced, “normal”)
10.8Vrms @0dBFS (balanced, “high”)
Line Output Level Balanced
2.7Vrms @0dBFS (single-ended with adaptors, “normal”)
5.4Vrms @0dBFS (single-ended with adaptors, “high”)
Line Output Impedance:
200 ohms (balanced)
100 ohm (unbalanced)
Dimensions
200x50x200mm
(W x H x D):
Weight:
1,7Kg
Condition: New old stock.
Contact: 0124549923
Price: 4300
Sonerin
Number of posts : 368
Registration date : 2011-12-03
Source(s): Oppo 203, Asus tinkerboard
Amplification: Magnet Medusa, Accuphase A-47
Speakers: CM8
M2tech Yound DSD DAC Empty Re: M2tech Yound DSD DAC
Post by Sonerin on Wed Apr 15, 2020 9:28 am
Sonerin
Speakers: CM8
Post by Sonerin on Tue May 05, 2020 10:13 am
Sonerin
Speakers: CM8
Post by Sonerin on Mon May 18, 2020 8:46 am
Sonerin
Speakers: CM8
Post by Sonerin on Sun May 31, 2020 7:07 pm
Sonerin
Speakers: CM8
Post by Sonerin on Fri Jun 12, 2020 9:39 pm
Sonerin
Speakers: CM8
Post by Sonerin on Sat Jun 27, 2020 11:39 am
Sonerin
Speakers: CM8
