Spatial Audio Hologram M1 Turbo Loudspeakers
Item: Spatial Audio Hologram M1 Turbo Loudspeakers
Condition: 8.5/10. In excellent condition. With original box.
Price:RM8.8k RM8.3k or swap/topup
Thank you.
[size=14]Spatial Audio Hologram M1 Turbo - The future of loudspeaker design is now available with the new Hologram Series. Box speakers are finally obsolete. The latest research into open-baffle loudspeaker technology has yielded a beautifully natural and transparent sounding loudspeaker in a compact, plug and play design. All Analog - no DSP required.The Hologram's precision response and musical character establishes a new paradigm in listener involvement. Even at very low listening levels the M1 & M2 maintain their dynamic awakeness and engagement. Hologram's Controlled Dispersion System greatly reduces room interaction, allowing consistent results in most any room environment.
SPECIFICATIONS:
[/size]
Actual item pictures:
Websites:
http://www.spatialaudio.us/store/hologram-m1
http://www.soundstageultra.com/index.php/equipment-menu/572-spatial-audio-hologram-m1-turbo-loudspeakers#most-read-equipment-reviews
http://www.reddragonaudio.com/products/spatial-hologram-m1
http://www.audioshark.org/spatial-audio-173/spatial-audio-hologram-m1-turbo-5933.html
http://www.audiocircle.com/index.php?topic=131007.0
Price: RM8.8k or swap/topup
Thank you.
Price:
Thank you.
Description
SPECIFICATIONS:
[/size]
- 2-way point source
- Open-baffle design with Dynamic Driver Controlled Directivity
- Chassis: 5 layer Aluminum Composite & MDF
- One 15 inch mid-woofer
- One 15 inch low woofer
- One wide bandwidth compression driver
- Crossover: Passive 800Hz - Hologram Network with WBT NextGen Binding Posts
- Frequency Response: 32Hz - 20kHz +/- 3dB
- Sensitivity: 95dBat 4Ω - averaged across 200Hz to 5kHz at 1M - on axis
- Impedance: 4Ω nominal, 3Ω minimum, low phase angle
- Dimensions: 36T x 20W x 3D inches (plus magnet depth),
- Weight: 50 lbs.
Websites:
Thank you.
» Spatial Hologram M4 Turbo S Loudspeakers (Used) SOLD
» SPATIAL AUDIO Hologram M1-Turbo in Malaysia.
» Spatial Audio X3 Speaker (SOLD)
» Spatial Audio M3 Turbo S Open Baffle Speaker (SOLD)
» Spatial Audio Hologram M3 Triode Master Open Baffle Speaker (SOLD)
