Paradigm Monitor 7 V3 Stereo Canada made floorstanding speaker
Price : RM 2580
Paradigm Monitor 7v3 Floorstanding Speakers
Made in Canada
Imaging, balance, build quality, and overall sound. Midrange is smooth and the highend is crystal clear. Also has quite a bit of bass for those without a sub.
The speakers I am reviewing are the version 3's. The look of these speakers is very simple yet attractive, they don't draw attention to themselves, which is what most want. As for the sound, I think it is one of the best values available. The imaging is great, and the overall sound is just outstanding. These speakers are for all listening groups and can handle all types of music very well. If you are looking for a step up from a budget system then definately take a look at the monitor line from paradigm.
Specifications for the Monitor 7 v.3:
Design 2-driver, 2 1/2-way bass reflex,
Quasi-3rd order resistive port
Crossover 3rd order electro/acoustic at 2.0kHz
2nd-order electro/acoustic at 400 Hz
High-Frequency Driver 25mm (1") PTD
Bass/Midrange Driver 165mm (6 1/2") ICP cone,
die-cast chassis
Bass Driver 165mm (6 1/2") carbon- infused cone die-cast chassis
Low Frequency Extension 33Hz (DIN)
Frequency Response On Axis-0 degrees +/-2db from 47Hz-20kHz
Off Axis-30degrees +/-2db from 47Hz-18kH
Sensitivity Room/Anechoic 93dB/90dB
Suitable Amplifier Power Range 15-175 watts
Maximum Input Power 120 watts
Impedance Compatible with 8 ohms
Internal Volume 45 L/1.60 cu ft
Height, Width, Depth 101.6cm X 19.4cm X 39.1cm
40in X 7 5/8in X 15 3/8in
Weight 34.5 kg/76 lb per pair
- Number of posts : 2893
Up
Up
Up
Up
Up
Up
