Pro-Ject Primary Phono USB Turntable (Demo unit clearance)
Pro-Ject Primary Phono USB Turntable (Demo unit clearance) Empty Pro-Ject Primary Phono USB Turntable (Demo unit clearance)
Post by Charles B&W TEG on Fri Apr 03, 2020 2:21 pm
Item: Pro-Ject Primary Phono USB Turntable
Colour: Available in Black, 1 unit left
Condition: Demo Unit
Price: RM1550.00 RM1162.50
Warranty: 1 Year
Contact: Please PM me to purchase.
Details:
Audiophile “Plug & Play” turntable with easiest possible set-up and class-leading sound!
If you thought that a turntable set-up is complicated like rocket-science, Primary proves the contrary. This good sounding belt-drive deck offers the fastest possible installation process because it comes pre-adjusted out of the box. No further set-up is needed. Tracking force and anti-skating are carefully set. An acrylic dust cover is included.
The turntable is available in matt black, matt red or matt white colour. Because Primary Phono USB comes with a pre-mounted cartridge and built-in phono preamplifier with USB output, connection to both line-level input of your hifi system and PC/Mac easily can be used simultaneously! Open-Source recording software Audacity is not based on a specific platform, it is available for free and the perfect solution for recording and processing of your audio data.
Review:
Feature
  • Manual "Plug & Play" Turntable
  • Speed Supported :33, 45 (manual)
  • Cartridge : Ortofon OM5e cartridge, pre-mounted
  • Instant playback with super-easy setup
  • Pre-adjusted tracking force & anti-skating force
  • 8,6” aluminium tonearm with sapphire bearings
  • Belt drive with silicone belt
  • Low vibration synchronous motor & DC power supply
  • Pre-mounted gold-plated RCA interconnect cable
  • Special turntable feet for effective decoupling
  • (USB Ver.) Built in USB & Phono Stage
  • Colours available : Black, White
  • Awards : What Hi-Fi? 5 Star, Hi-Fi Choice Recommended
Technicial Specifications
  • Speed: 33,45 (manual speed change)
  • Principle: Belt drive
  • Speed variance: 33: 0.8% 45: 0.7%
  • Wow & Flutter: 33: 0.29% 45: 0.27%
  • Platter: 300 mm with felt mat
  • Main bearing: Stainless steel
  • Tonearm: 8.6” aluminium
  • Effective arm length: 218.5 mm
  • Overhang: 22.0 mm
  • Effective tonearm mass: 8.0 g
  • Counterweight for mass: 3 - 5.5 g (pre-mounted)
  • Tracking force range: 0 - 25mN (17.5 mN pre-adjusted)
  • Included accessories: Dustcover
  • Power consumption: 4.5 Watt max
  • Dimensions: 420 x 112 x 330 mm (WxHxD)
  • Weight: 4.0 kg nett
Charles B&W TEG
Number of posts : 201
Registration date : 2019-01-25
Pro-Ject Primary Phono USB Turntable (Demo unit clearance) Empty Re: Pro-Ject Primary Phono USB Turntable (Demo unit clearance)
Post by Charles B&W TEG on Tue Apr 14, 2020 3:55 pm
Charles B&W TEG
Post by Charles B&W TEG on Tue Apr 28, 2020 10:47 am
Charles B&W TEG
Post by Charles B&W TEG on Fri May 08, 2020 12:21 pm
Charles B&W TEG
Post by Charles B&W TEG on Thu May 21, 2020 11:03 am
Charles B&W TEG
Post by Charles B&W TEG on Thu Jun 04, 2020 11:25 am
Charles B&W TEG
Post by Charles B&W TEG on Wed Jun 24, 2020 1:05 pm
Charles B&W TEG
Post by Charles B&W TEG on Thu Jul 02, 2020 2:57 pm
Charles B&W TEG
Post by Charles B&W TEG on Wed Jul 29, 2020 6:12 pm
Charles B&W TEG
