Pro-Ject Essential III SB Turntable
Pro-Ject Essential III SB Turntable Empty Pro-Ject Essential III SB Turntable
Post by Charles B&W TEG on Fri Apr 03, 2020 9:32 am
Item: Pro-Ject Essential III SB Turntable
Colour: Available in Red
Condition: Brand New
Price: RM2300.00 RM2185.00
Warranty: 1 Year
Contact: Please PM me to purchase.
Details:
The comfy one with integrated speed change
Going from 33.3 to 45 rpm, and vice versa, within a second? The Essential III SB is the perfect companion for everyone who needs to change vinyl in a hurry.
Essential III SB is the one to chose when it comes to comfort needs. Essential III SB allows the listener to change speeds with the push of only a single button.
Essential III offers a variety of enhancements compared to its successful predecessor, such as a diamond-cut aluminum drive pulley, a resonance-optimized MDF main platter and MDF chassis. The refined, high-precision platter bearing has significantly lower tolerances than Essential II. Essential III is equipped with an 8,6” aluminium tonearm with the high-quality pickup OM10 by the phonographic cartridge pioneer Ortofon. The included Phono RCA cable, Connect it E, is a high-quality semi-balanced interconnect cable with gold-plated RCA connectors that guarantees the perfect connection. Also the special decoupling feet isolate the turntable from the surface it is place on to deliver the best sound possible.
Feature
  • Belt drive with synchronous motor and silicone belt
  • Built-in USB output to record on your PC/Mac
  • Speed Box built in
  • Diamond cut aluminium drive pulley
  • Chassis & platter made of resonance in-sensitive MDF
  • Integrated DC-powered motor control minimizes motor vibration and guarantees speed stability
  • Low tolerance platter bearing with strainless steel spindle
  • 8,6” aluminium tonearm with sapphire bearings
  • Ortofon OM10 cartridge pre-mounted
  • High-quality semi-balanced Connect it Ephono interconnect with gold-plated RCA connectors included
  • Special decoupling feet
  • Dust cover included
Technicial Specifications
  • Speed: 33, 45 (electronic speed change)
  • Drive principle: belt drive
  • Wow and flutter: 33: 0,70% 45: 0,60%
  • Speed drift: 33: 0,21% 45: 0,19%
  • Platter: 300mm MDF
  • Main platter bearing spindle: stainless steel
  • Tonearm: 8,6”, aluminium
  • Effective arm length: 218,5 mm
  • Overhang: 22,0mm
  • Effective tonearmmass: 8,0 gr
  • Suitable cartridge mass: 3 - 5,5g
  • Tracking force: 0 - 25mn (recommended for OM10 18mn)
  • Included accessory: power supply, dust cover, felt mat
  • Power consumption: 4,5 watts max
  • Dimensions (lid closed): 415 x 112 x 335mm (WxHxD)
  • Dimensions (lid open, 90°): 415 x 365 x 390mm (WxHxD)
  • Weight: 5,0 kg net
Charles B&W TEG
Number of posts : 121
Registration date : 2019-01-25
Pro-Ject Essential III SB Turntable Empty Re: Pro-Ject Essential III SB Turntable
Post by Charles B&W TEG on Tue Apr 14, 2020 10:58 am
Charles B&W TEG
Post by Charles B&W TEG on Tue Apr 28, 2020 5:50 am
Charles B&W TEG
Post by Charles B&W TEG on Fri May 08, 2020 7:19 am
Charles B&W TEG
Post by Charles B&W TEG on Thu May 21, 2020 6:02 am
Charles B&W TEG
