Dayton Audio DSP-408 Processor
Dayton Audio DSP-408 Processor Empty Dayton Audio DSP-408 Processor
Post by paradis on Mon Apr 13, 2020 10:27 pm
Clearing my inventory during MCO, and have this up for sell, really this is the cheapest mean to have a processor and start working with crossover/eq/time-alignment, its in an open box condition, rated as 9/10 as it is not new but everybit of it will tell you this is like-new condition :-)
I've not spend much time as over the course of this item arrival i went for MiniDSP SHD (that came with a streamer built-in) hence this is never put in place.
Asking for RM780 nett including poslaju; just to covered my cost. Interested please PM or Whatsapp 01131347900
This is pretty versatile, accepting a 12v input where you can uses your LPSĀ  to feed it a better power (the usual walmart adapter are included). A lot of people uses this in either home or car environment, achieving great result.
    Software Features:• 10-band parametric equalizer per channel• High and low shelf EQ per channel• Variable crossovers: High/Low/Band-Pass slopes 0-24 dB, Linkwitz Riley/Butterworth/Bessel• Time delay: 0 to 277 cm or 8.1471 ms adjustable in 1 cm steps• Input/Output mixing to customize the signal path• Phase adjustment• Customizable name/ID for each of the 6 presets• Load, save, recall, or delete preset files• Software controllable level attenuation on the preamp and high-level inputs• Minimum/maximum voltage protection• Reverse voltage protection• Mute circuit and delay
paradis
Number of posts : 340
Registration date : 2014-08-21
Dayton Audio DSP-408 Processor Empty Re: Dayton Audio DSP-408 Processor
Post by paradis on Mon Apr 20, 2020 1:54 pm
up the thread.
A great DSP for the price, allows you to have EQ/Time alignment...or if this is not for the purist, this also provide you capability to leverage for a good integration of subwoofer into the system :-)
paradis
Post by paradis on Sat Apr 25, 2020 4:53 pm
up the thread
paradis
Post by paradis on Sun May 10, 2020 11:33 pm
up the thread
paradis
Post by paradis on Fri May 29, 2020 1:27 am
up the thread
paradis
Post by paradis on Mon Jun 08, 2020 9:28 pm
up the thread
paradis
Post by paradis on Sun Jun 21, 2020 11:25 pm
Up the thread
paradis
