Shunyata Research Venom Speaker Cable - 2.5m pair
Shunyata Research Venom Speaker Cable - 2.5m pair Empty Shunyata Research Venom Speaker Cable - 2.5m pair
Post by raymond88 on Tue May 12, 2020 11:00 pm
Item: Shunyata Research Venom Speaker Cable - 2.5m pair
Condition: 8.9/10. Item is in MINT condition. Only a few months old. Selling due to upgrade.
Price: RM2700 or swap/topup
Retail Price: RM3900.00
https://www.lazada.com.my/products/shunyata-venom-speaker-cable-25m-i528926622-s1045480559.html?exlaz=d_1:mm_150050845_51350205_2010350205::12:1032211143!54400014687!!!pla-296303633664!c!296303633664!1045480559!135214038&gclid=CjwKCAjwkun1BRAIEiwA2mJRWeCrLBdJHAzocdZpApSIjmvOYvqVS1KpuKSa0FtxsPwypgaNrxalXBoC3ywQAvD_BwE
Shunyata Research Venom Speaker Cable - 2.5m pair S410
VENOM Series signal and speaker cables represent fifteen years of Shunyata Research’s evolved technical innovation and custom-parts engineering. The over-reaching goal was to create products that possess peerless quality and performance, at real-world prices. You’ll find that the finest in signal cable performance need not cost a fortune.
DESCRIPTION
OVERVIEW
  • OFE 101 Certified Copper
  • VTX™ Conductors (hollow-core)
  • 100% coverage electro-static shielding
  • STIS™ – Interchangeable Speaker Cable Terminals
  • Stunning Aesthetic
  • Very Flexible Cables
  • Incredible Value
APPLICATIONS
All music and sound systems, recording environments and studio systems.
TECHNOLOGY
Shunyata Research uses only the highest purity of copper available for the production of its wire products. ‌‌OFE Alloy 101 or ‌‌C10100 is the highest grade of copper with a minimum 99.99% purity and a conductivity rating of 101% IACS. OFE stands for oxygen-free electrolytic and supersedes the term OFHC (oxygen-free high conductivity). ‌‌C10100 is the only grade of copper that comes with a written certification of purity. Certified by ASTM F68 ‌‌C10100.
Ohno wire, also called ‌PCOCC was invented in 1986 by professor Atsumi ‌Ohno of the Chiba Institute of Technology in Japan. Copper wire is created by an extrusion process that pulls a rod of cold copper through a small orifice which creates multiple crystalline boundaries. By contrast, ‌‌Ohno wire is made by a process using heated molds that cast a wire to form a single crystalline structure. ‌‌Ohno wire is well known for its exceptionally pure, grain-free sonic qualities.
Shunyata Research's exclusive ‌VTX:tm: conductors are made in the shape of virtual tubes. The core of the conductor is completely hollow minimizing skin effects and random eddy currents. They are produced using OFE Alloy-101.
ArNi:registered: is a type of wire created by Shunyata Research designed to be the finest quality wire available for audio purposes. It begins with the highest purity of copper available – OFE C10100 or Ohno (single crystal). Then it is formed in virtual hollow tubes eliminating skin effects and eddy current distortions. In addition, the wire undergoes our proprietary KPIP:tm: process.
The ‌STIS:tm: speaker terminal system was designed to eliminate the high cost and complication of speaker cable termination. The system makes it possible to use the same speaker cable with a variety of different amps and speakers. If a spade is damaged, you can simply replace it without sending it to the factory for re-termination. ‌‌STIS:tm: interchangeable terminals have undergone extensive user listening tests to insure that they provide the finest audio performance that is equal or superior to non-replaceable, soldered terminals.
Shunyata Research Venom Speaker Cable - 2.5m pair S119
Shunyata Research Venom Speaker Cable - 2.5m pair S219
Shunyata Research Venom Speaker Cable - 2.5m pair S319
https://www.thecableco.com/venom-speaker-cable-pair.html
https://www.dedicatedaudio.com/products/shunyata-research-venom-speaker-cables-pair
https://www.moremusic.nl/reviews/shunyata/Venom/Shunyata_Venom_interc_loudsp_AbSo.pdf
https://www.theabsolutesound.com/articles/shunyata-research-venom-interconnects-and-speaker-cables/
http://www.theaudiobeat.com/equipment/shunyata_research_venom.htm
Number of posts : 6159
